Scott Kelby has explained how to update old Raw files to a new profile.
Part of the explanation states "Make sure that Auto-Sync is turned on. (It's that little toggle switch to the left of "Sync" at the bottom of the right side panels"
I can't see it. Here's a screen capture to illustrate ....
Cliff
You're not looking low enough. It's right above the filmstrip.
When you click on that little switch, Sync will change to Auto Sync. But you must have multiple images selected in order to see the feature.
Hi Cliff,
You need to look further down, at the bottom of the right-hand panel:
Mike
My version 7.3.1 Camera Raw 10.3 doesn't appear to have have the same layout as your screen capture.
And I don't see that toggle anywhere at all.
Yours, Cliff
Bingo!
Thank you SO much...
Cliff
Where is this toggle switch in the new 2018 Lightroom?
It's in the same place in Develop, lower-right corner, and it only appears when you have more than photo selected.
If you don't see it, verify you are running Lightroom Classic CC and not Lightroom CC by doing the menu command Help > System Info. If you're not sure of the differences between those two confusingly named versions of Lightroom, see here: https://www.lightroomqueen.com/the-future-of-lightroom/
