Working on a 2017 iMac, Premiere Pro version 12.1.0 (Build 186)
As you'll see in this screencast, dragging from the source monitor to the sequence fails. Using Insert (,) works fine.
Just keeping track of the bugs in the new version.
Not a bug just an user error:
Use the Selection Tool not the Hand tool.
for me it works fine on macbook pro, im thinking what it could be
Thanks Ann,
I'll try that. I'm pretty sure I was using the Selection Tool (I never use the hand tool) but maybe I hit an errant H and changed the tool selection. Thanks for the heads up, though!
C
Ann is correct. You can clearly see the Hand Tool is active in the screen capture
DOH!
