I have this new problem with Photoshop CC 2018.
When I go to Preferences > Performance, PS is seeing only 3GB of RAM out of my total 8GB. I cant adjust the slider to let PS use more than 3GB.
I am using PS for about a year now and I did not encounter this problem before.
I am running the 64bit version, at least the info in PS says so.
System info:
Hi
Adobe released Photoshop 19.1.5 today which fixes the issue.
Once installed, to allow Photoshop to manage memory - the temporary fix needs to be removed . See this :
Error while accessing performance preferences - 'An integer between 96 and 8 is required.'
Dave
Hello, have you tried resetting your preferences? Preferences in Photoshop
Yes, tried that just now. It did not help, still seeing only 3gigs available. Also tried reinstalling PS.
As I understand we'll need to wait for the next update for this issue to be solved.
Hi there!
I'm having the same issue with my Photoshop cc.
I've done a clean install and still get the same.
Any updates on this?
Thanks heaps!
Hello, there is a workaround that involves tweaking the registry before a fix to the software that cures the issue created by the fall creators update from Microsoft : Invalid Numeric Entry - An integer between 96 and 8 is required
Hello, this seems to work for now. I hope Photoshop really uses all that memory though. Thank you very much
Totally solved my problem, Thank You Have A Wonderfull Day
Hi
Dave
