Hi, I have been having issues with Premiere Pro constantly crashing. Below is a screenshot.
It has happened more than 10 times now and I have tried to update Premiere Pro, my GPU drivers, and I've switched to Mercury Playback Engine Software Only but it still crashes.
In fact, it runs much more slowly without GPU acceleration (expected) but still crashes.
My PC specs:
i5-7600k CPU
16GB Ram
Nvidia GeForce GTX 1070 GPU
500GB M2 SSD
I edited my whole video and started touching up some spots with a mask and then the crashes started; so I am blocked at this point.
Please help!
Windows 10
Premiere Pro 2018
The video is in 1080p 24 FPS
It just happened again while manipulating a mask and I got an error saying bad_module_info has stopped working.
I've been able to reliably replicate the issue by removing a point on a Lumetri Color Mask with Ctrl-Click. I've also tried clearing the media cache and I checked my PC for memory issues via mdsched
Hello,
I've had this issue after long working hours, when manipulating masks. You should try to contact Adobe Tech support directly. I suspect a GPU issue, but difficult to say as your specs are more than enough for 1080p encoding/color correcting.
Hi, I am also having the same issue.
All of my equipment and software is up to date.
Mac specs:
Mac Pro late 2013 (apple trash can)
Processor 2.7 ghz 12 core intel Xeon E5
Memory 64gb 1866 MHz DDR3
GFX AMD FirePro D700 6gb
Has anyone found a solution to this problem?
Same problem here (High Spec PC, Latest version of Premiere) There seems to be far too many bugs in Premiere Its almost unusable. Its constantly moaning about something! I wish I'd gone for Final Cut.
Similar issue in Premiere 2020 (latest version in January 2020)
Currently I'm trying to apply blur using a mask (and track it). The tracking didn't work so i had to manually re-track which is when this error occured.
I get the error message and soon premiere crashes.
Working with:
intel i7 9700 @3 gHz
Nvidia geforce RTX 2060
16 gigs of RAM
Premiere installed on an SSD
I'm getting this error too. When this happens, quite a bit of my work does not save (although some gets saved in the Auto-Save files).
Here are my specs:
Premiere Pro ver 22.4.0 build 57
Windows 10 Enterprise
Ver 21H1
Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz 2.59 GHz
16.0 GB (15.8 GB usable)
