I'm using Adobe Pro DC. My PDF documents must be saved so the bookmarks are displayed when it's opened. Can the document properties by set to default to these settings so I don't have to set them each time? => file properties | initial view | navigation tab (bookmark/panel&page) | page layout (single page continuous) | magnification (fit width) | open to page 1
Thank you.
Not possible.
Not possible.
Thank you.
That pretty much sucks. "Preferences" don't seem to mean much if they aren't used by default. meh.
DC = "Don't Count on it"
Pretty discouraged by the features, functionality and wonky interface - across the board. No offense, it was kind of you to answer, even so tersely. You are a helpful contributor, I know this. It just is quite a disappointment that preferences are no longer treated as preferences, you know?
I have a similar issue, using Acrobat DC, All my PDF documents open with the Bookmark Panel on the side. Is there a way to not have this feature? I want my PDF documents to open with these settings;
Is that possible?
Thanks.
Change the initial view in Adobe Acrobat.
