2 Replies Latest reply on May 12, 2018 4:38 PM by Michel [FRIdNGE]
    Script to extract column from a table and paste it as a text frame
    el-cerezo
      Hi, everybody!
      I wonder if there's a way —or maybe there's a script that already exist— to convert all columns from all tables in a document to individuals text frames with the same high and widh lenght that had as table columns and preserving the same paragraph style from each cell.
        • 1. Re: Script to extract column from a table and paste it as a text frame
          S Hopkins Adobe Community Professional
          The following sample script demonstrates getting the information you want from a table.
          set colInfo to {}
          tell application "Adobe InDesign CC 2018"
            set tableRef to table 1 of story 1 of document 1
            set colList to columns of tableRef
            repeat with i from 1 to length of colList
            set thisCol to item i of colList
            set celList to cells of thisCol
            set wid to width of thisCol
            set totHgt to 0
            set celInfo to {}
            repeat with j from 1 to length of celList
            set thisCel to item j of celList
            set c to contents of contents of thisCel
            set s to applied paragraph style of paragraph 1 of thisCel
            set h to height of thisCel
            set end of celInfo to {c, s}
            set totHgt to totHgt + h
            end repeat
            set end of colInfo to {celInfo, wid, totHgt}
            end repeat
          This creates a nested list of lists that you can then parse to create your text frames with contents and styling. Hope this helps.
          • 2. Re: Script to extract column from a table and paste it as a text frame
            Michel [FRIdNGE] Level 4
            Just by curiosity! … For what use?
            Best,
            Michel, from FRIdNGE
