8 Replies Latest reply on May 11, 2018 12:17 PM by pixxxel schubser
    Replace a letter using GREP without interfering in the GREP syntax
    manuelb27477138 Level 1
      Hello!
      Before the letter D, I try to insert a Column Break (in GREP is the character ^M) in my Index. But I can't because in GREP ^D means other thing and is not working the script.
      Is important be sure don't damage other letters D
      How can I add a column break before my single letter D ?
      replaceText ("^D\r","^MD\r")
      function replaceText (input, output)
           app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
           app.findTextPreferences.findWhat = input;
           app.changeTextPreferences.changeTo = output;
           app.activeDocument.changeText();
      My actual Index:
      The result I expect:
      Thanks so much in advance!
        • 1. Re: Replace a letter using GREP without interfering in the GREP syntax
          pixxxel schubser MVP & Adobe Community Professional
          Try this:
          Have fun
          Aktualisiert
          (too much security)
          ^(D)$  is sufficient
          • 2. Re: Replace a letter using GREP without interfering in the GREP syntax
            Hi !
            Is funny because in Indesign using the normal Panel Find/change is working.
            But with my code is not working. Do you thing this kind of GREP are not working in the scripts? or maybe is something wrong in my script?
            replaceText ("^([D])$","~M$1")
            Thanks a lot !
            • 3. Re: Replace a letter using GREP without interfering in the GREP syntax
              You cannot use changeGrep with TextPreferences syntax.
              This should work.
              replaceText ("^(D)$","~M$1")
                  app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
                  app.findGrepPreferences.findWhat = input;
                  app.changeGrepPreferences.changeTo = output;
                  app.activeDocument.changeGrep();
              Have fun
              • 5. Re: Replace a letter using GREP without interfering in the GREP syntax
                here my final script, maybe help to someone:
                // Source: https://forums.adobe.com/thread/708641
                // This Script allow you to find a replace a Text using 2 syntax FIND or GREP. Becarefull, affects the text of the entire document. The sintaxis of your queries are different if you use FIND or GREP, exaclty same like when you find and replace with the indesign window.
                // https://helpx.adobe.com/indesign/using/find-change.html#find_and_change_objects
                // To replace with GREP a simple Index Setion Heading, for example the letter D, you can use simple this ^(D)$ but if you want extra security use this ^([D])$
                /******** FIND AND REPLACE TEXT USING GREP ********/
                replaceTextUsingGREP ("^([D])$","~M$1"); // add a Break Column before letter D (Index Section Heading)
                function replaceTextUsingGREP (input, output)
                /******** FIND AND REPLACE TEXT USING FIND ********/
                replaceTextUsingFIND ("yourText", "^MyourText");  //add a Break Column
                replaceTextUsingFIND ("yourText2\r", "yourText2\r");  // add many queries as you want
                function replaceTextUsingFIND (input, output)
                • 6. Re: Replace a letter using GREP without interfering in the GREP syntax
                  You're welcome.
                  (But please change 'extra security' to 'unnecessary'.)
                  • 7. Re: Replace a letter using GREP without interfering in the GREP syntax
                    Here the final code, thanks to pixxxel schubser!
                    // This Script allow you to find a replace a Text using 2 syntax FIND or GREP. Becareful, affects the text of the entire document. The sintaxis of your queries are different if you use FIND or GREP, exactly same like when you find and replace with the indesign window.
                    // To replace with GREP a simple Index Section Heading, for example the letter D, you can use simple this ^(D)$ but if you want unnecessary use this ^([D])$
                    replaceTextUsingGREP ("^(D)$","~M$1"); // add a Break Column before letter D (Index Section Heading)
                    • 8. Re: Replace a letter using GREP without interfering in the GREP syntax
                      manuelb27477138  schrieb
                      … you can use simple this ^(D)$ but if you want unnecessary use this ^([D])$  …
                      That's really funny. I'm amused. Thank you
