Hello Everyone.
I have a Sony PXWZ150, and I can shoot: Record Format: 1080/24p 50Mbs, Frame Rate: 60fps, 120fps. If I bring the Sony Footage Into Premiere, It Is already a Slow Motion Footage.
With my Canon 80D, By Default, I can shoot: 1920 By 1080, 59.94p, and By Default the Shutter is set to 60. If I bring the Canon 80D footage Into Premiere, It dose not play slow Motion. This is what I was told to do:
1- Bring the 80D Footage Into premiere
2- Inside Sequence Settings: Change the Timebase from 59.94 To 23.976
3- Right Click on the Timeline Footage, Speed/Duration, and change it to 40%
4- Unlink the Video from Audio, and Delete the Audio.
Do I have to do all these steps ?
What Is the correct Technique?
What If I shoot normal, and only bring the Footage Into Premiere, and only change the Duration to 40%, Rather than going through all these Steps?
Thank you very much.
Do the following
1 - Select the Clip
2 - Clip >> Modify >> Interpret Footage
(On Frame Rate) >> Assume this Frame Rate and Change it to 23.976
This Might Hep you
Do the following
1 - Select the Clip
This Might Hep you
