My Foolish Question
Feb 16, 2009 Feb 16, 2009
Hi People I am using a cfffunction and returntype is array.
I am using on my cfm page and try to get the values i am getting error:
<cfinvoke component="showall" method="getDBTableStruct" tablename="#url.table#" returnvariable="tableData"/>
<cfdump var="#tableData#">
<cfset wibble = getDBTableStruct() />
<cfoutput>#wibble[ColumnName]#</cfoutput>
</cfif>
The web site you are accessing has experienced an unexpected error.
Please contact the website administrator.
The following information is meant for the website developer for debugging purposes.
Error Occurred While Processing Request
Variable GETDBTABLESTRUCT is undefined.
The error occurred in C:\Inetpub\wwwroot\p1\index.cfm: line 117
115 : <cfinvoke component="showall" method="getDBTableStruct" tablename="#url.table#" returnvariable="tableData"/>
116 : <cfdump var="#tableData#">
117 : <cfset wibble = getDBTableStruct() />
118 : <cfoutput>#wibble[ColumnName]#</cfoutput>
119 : </cfif>
Ok When I Dump i get The Following:
array
1
struct
AllowNulls false
CF_DataType CF_SQL_INTEGER
ColumnName ban_id
Increment true
PrimaryKey true
Special [empty string]
2
struct
AllowNulls true
CF_DataType CF_SQL_VARCHAR
ColumnName ban_title
Increment false
PrimaryKey false
length 255
3
struct
AllowNulls true
ColumnName ban_img
Increment false
PrimaryKey false
length 255
4
struct
AllowNulls true
CF_DataType CF_SQL_LONGVARCHAR
ColumnName ban_link
Increment false
PrimaryKey false
5
struct
AllowNulls true
ColumnName ban_hits
Increment false
PrimaryKey false
6
struct
AllowNulls true
ColumnName ban_active
Increment false
PrimaryKey false
length 255
Advanced techniques
1.5K
this line in your code
calls some cf udf/function named 'getDBTableStruct'
i suspect you do not have such a udf/function, but you rather want to
use the array/query returned by your <cfinvoke> call? then you need to
change the above to:
<cfset wibble = tableData />
or, rather, omit this line altogether: no need to duplicate variables -
you already have tableData var returned by your <cfinvoke>
this next line in your code:
will error, too - unless you have ColumnName variable defined in your
page...
if your cfc function returns an array, you need to cfloop over the array
to output any of its elements.
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
why are you doing this <cfset wibble = getDBTableStruct() /> ?
Are you trying to see/loop through the output structure retruned by the function..?
If so this variable tableData will have the information you require. I think...
Okay Here i tried through the Loop way but did not work:
<cfloop from="1" to="#arrayLen(tableData)#" index="i">
<cfoutput>#tableData #<br /></cfoutput>
</cfloop>
</cfif>
Errors out as:
Complex object types cannot be converted to simple values.
The expression has requested a variable or an intermediate expression result as a simple value, however, the result cannot be converted to a simple value. Simple values are strings, numbers, boolean values, and date/time values. Queries, arrays, and COM objects are examples of complex values.
The most likely cause of the error is that you are trying to use a complex value as a simple one. For example, you might be trying to use a query v
Well are us saying i hsould convert it into a Structure and then loop over the Structure.
Well isn't there a way i can just loop over the returnvariable tableData and output the results.
Cheers
After seeing the function name getDBTableStruct(), I thought it is returning a struct value. If it is returning a result set because of a DB query call, then try using looping over a query like belwo:-
<cfloop query = "tableData"
<cfoutput>#tableData.ColumnName#</cfoutput>
</cfloop>
Details are here:-
http://livedocs.adobe.com/coldfusion/7/htmldocs/wwhelp/wwhimpl/common/html/wwhelp.htm?context=ColdFu...
I hope this would help.
Ok My CFC is returning this:
<cffunction name="getDBTableStruct" access="public" returntype="array" output="no" hint="I return the structure of the given table in the database.">
<cfargument name="tablename" type="string" required="yes">
<cfscript>
var qRawFetch = 0;
var arrStructure = 0;
var tmpStruct = StructNew();
var i = 0;
var PrimaryKeys = 0;
var TableData = ArrayNew(1);
</cfscript>
<cfset qRawFetch = runSQL("SELECT TOP 1 * FROM #arguments.tablename#")>
<cfset arrStructure = getMetaData(qRawFetch)>
<cfif isArray(arrStructure)>
<cfloop index="i" from="1" to="#ArrayLen(arrStructure)#" step="1">
<cfset tmpStruct = StructNew()>
<cfset tmpStruct["ColumnName"] = arrStructure .Name>
<cfset tmpStruct["CF_DataType"] = getCFDataType(arrStructure
.TypeName)>
<!--- %% Ugly guess --->
<cfif arrStructure .TypeName eq "COUNTER" OR ( i eq 1 AND arrStructure.TypeName eq "INT" AND Right(arrStructure .Name,2) eq "ID" )>
<cfset tmpStruct["PrimaryKey"] = true>
<cfset tmpStruct["Increment"] = true>
<cfset tmpStruct["AllowNulls"] = false>
<cfelse>
<cfset tmpStruct["PrimaryKey"] = false>
<cfset tmpStruct["Increment"] = false>
<cfset tmpStruct["AllowNulls"] = true>
</cfif>
<cfif isStringType(arrStructure
.TypeName) AND NOT tmpStruct["CF_DataType"] eq "CF_SQL_LONGVARCHAR">
<cfset tmpStruct["length"] = 255>
</cfif>
<cfset tmpStruct["Special"] = "">
<cfif Len(tmpStruct.CF_DataType)>
<cfset ArrayAppend(TableData,StructCopy(tmpStruct))>
</cfif>
</cfloop>
<cfelse>
<cfthrow message="Error Found." detail="NoMSAccesSupport">
</cfif>
<cfreturn TableData>
</cffunction>
what exactly does you cfc function return?
can you post your cfc function code?
Azadi Saryev
Sabai-dee.com
oops - you are using the wrong CFLOOP, as the variable is a straucture, you cannot loop it using the above, try using looping like a collection. Details are here http://livedocs.adobe.com/coldfusion/7/htmldocs/wwhelp/wwhimpl/common/html/wwhelp.htm?context=ColdFu...
ok - it is returning an array and if I see your code (while you are looping through it as an array), you have written it as :-
<cfoutput>#tableData#<br /></cfoutput>
</cfloop>
I think it should be:-
</cfloop>
i.e instead of tableData, try tableData
inside cfoutput
oops, somehow "i" missed out, i.e inside cfoutput it shoudl be tableData of i
I tried both way: like this:
<cfoutput>#tableData[ ]#<br /></cfoutput>
</cfloop>
and like this:
</cfloop>
it works neither way it shows only the above error: Complex object types cannot be converted to simple values.
it looks like what your function returns is an array of structures. thus
elements of your array are structures and not simple values - hence the
error.
try this:
<cfloop from="1" to="#arrayLen(tableData)#" index="x">
<cfloop collection="#tabledata#" item="key">
<cfoutput>#key#<br /></cfoutput>
</cfloop>
</cfloop>
alternative:
<cfloop array="#tabledata#" index="a">
<cfloop collection="#a#" item="key">
</cfloop>
</cfloop>
Azadi Saryev
Sabai-dee.com
Thanks Azadi You Rock Dude!!!!
It displays the list of all stuff i am on to:
i want them to appear in my tables but i am confused:
here is my code:
<tr>
<td><cfinput type="text" name="tcolumnName" value="#key#" readonly="yes"></td>
<td><cfinput type="text" name="ttexttype" value="#key#"></td>
<td><input type="checkbox" name="tIS_NULLABLE" <cfif #key# IS 'yes'>checked="checked" value="Null"<cfelse>value="Not Null"</cfif>></td>
<td><cfinput type="text" size="4" value="#key#" name="tlength"></td>
</tr>
</cfloop></cfloop>
do i need to some way or other way:
P.S I am noob in CF and would like to know more. Please guide me
here is my code:
<tr>
</tr>
</cfloop></cfloop>
it displays like
i want columnName should appear under columName and datatype under datatype but not working that way
Column Name: Data Type: Is Nullable: Key:
well, for starters, your <tr> tag should be before <cfloop
collection...> tag (and the closing </tr> should be after the closing
</cfloop> for the collection loop).
your table rows will be created by the outer loop (over the array
length), but the cells will be created by the collection loop.
you will also have to either have a <td> for each key of your structure
following the order they were defined in your cfc function, or, if you
want to output only some keys of your structure, to <cfif> to check for
the key name before you create the form element for it...
and if you need to output the VALUE of the key, you have to cfoutput not
#key# but #tabledata[key]#. #key# will output the NAME of the key,
not its value...
the following code should produce the output close to what you want, i
think:
<tr>
<td>
<cfif key eq "ColumnName">
<cfinput type="text" name="tcolumnName" value="#tableData[key]#"
readonly="yes">
<cfelseif key eq "CF_DataType">
<cfinput type="text" name="ttexttype" value="#tableData[key]#">
<cfelseif key eq "AllowNulls">
<input type="checkbox" name="tIS_NULLABLE" value="1" <cfif
tableData[key] is true>checked="checked"</cfif>>
<cfelseif key eq "length">
<cfinput type="text" size="4" name="tlength" value="#tableData[key]#">
</cfif>
</td>
</cfloop>
</tr>
</cfloop>
hth
Azadi Saryev
Sabai-dee.com
I don't see you using your index anywhere in your cfoutput.
By the way, on these forums, if you surround the letter i with square brackets, the rest of your text gets converted to italics and what you are trying to display does not get displayed. Use ii instead of i.
hmm... i believe in his case that would output 1, 2, 3,.... since he's
looping not over an array, but over an array length
Azadi Saryev
Sabai-dee.com
Documentation
