Hello,
I fell that my Photoshop isn't working as well as i expect. I set up a new System some weeks ago (AMD 1950X, Nvidia 1080 Ti, 32GB DDR 4 3200, Bootdisk Samsung 850 Pro, Working Disk Samsung 960 Pro)
Opening Photoshop takes in my opinion too long. When I open Images in Camera Raw and import them into Phtoshop as Smart Objects it also takes long (6 Files, 146 MB), I measured nearly 30 Seconds for starting Photoshop and open all images.
Should this not be much faster?
Is there any benchmark for photoshop to test? Or does anyone have a similar system and can give me some feedback about?
Thanks!!
Hi Stefan,
As you're Photoshop is not performing as expected, could you please let us know which version of Photoshop are you using and also on which operating system?
Sahil
Hi Sahil,
I use Photoshop CC 2018 and Windows 10 Pro 64 bit.
I think the problem is that you are reading files directly from the SD-card. And the speed of reading and the response of the device take this time.
Try to open your failes from SSD or NVMe SSD and compare.
I have similar configuration and it work perfect!
Along with the previous suggestions, an area to check are your Performance Preferences. Photoshop > Preferences > Performance and make sure it is set as you desire.
