When keywording in browser commonly used words would appear on the side.
After installing the updated CC this feature is not there, which INCREASES the
TIME I have to spend doing keywording. What am I missing? Is it sitll there
somewhere?
Hello, did look in the windows menu if the metadata panel is not available ? Did you look in the workspaces switcher if one of the different ones is not there?
Or, do you mean that the list is empty ?
in this case, you can export and import it from your previous install of Bridge.
I do not add keywords but are you referring to Browse in Bridge... and using Ctrl+F5 to switch to the Keywords workspace? Bridge CC2018 seems to work OK for standard metadata keywords like Aperture Value and I can filter for example f/2.8.
