18 Replies Latest reply on May 15, 2018 8:59 AM by manuelb27477138
    Apply Paragraph Styles Depending on Text Values
    manuelb27477138 Level 1
      Hello everyone!
      I want apply my custom Paragraph Styles to some text, this text have a similar Styles but not the same.
      Is possible create many conditionals and apply my Custom Paragraphs Styles depending on Text Values?
      For example: in my file Indesign.indd I want find the texts with the next values and apply my Custom Paragraph Style called Text Number locate in my folder NEW STYLES.
                 fontStyle == "Roman",
                  pointSize <= 10.5,
                  spaceAfter <=1,
                  spaceBefore <= 3.292,
                  leftIndent <= 7.408,
                  rightIndent <= 0,
                  firstLineIndent <= -7.408,
                  hyphenation: false,
                  justification == Justification.LEFT_ALIGN || justification == Justification.LEFT
      Please this script is very important for me, I appreciate any help.
      Thanks so much!
        • 1. Re: Apply Paragraph Styles Depending on Text Values
          Loic.Aigon Adobe Community Professional
          As far as I know you won't be able to set logical values. But you could still look at some base set or properties and loop through results to see if they have any of the multiple possible values.
          • 2. Re: Apply Paragraph Styles Depending on Text Values
            Hi Loic,
            Do you have any code o example, just for start from scratch? sorry, I am beginner.
            I search a lot in Google but I can't find examples.
            • 3. Re: Apply Paragraph Styles Depending on Text Values
              There are probably many similar samples inside the forum.
              As it seems you only have one static value (i.e. hyphenation), you could start this way:
              //MAIN FUNCTION
              var main = function() {
              //VARS
              var doc = app.properties.activeDocument,
              fgp = app.findGrepPreferences.properties,
              texts = [], n = 0, nthText, myParaStyle,
              paraStyleName = "some para style name";
              //Exit if no documents open
              if ( !doc ) {
              alert("You need an open document" );
              return;
              //Create ParaStyle if needed. Otherwise use it
              myParaStyle = doc.paragraphStyles.item ( paraStyleName );
              if ( !myParaStyle.isValid ) myParaStyle = doc.paragraphStyles.add ( paraStyleName );
              //Setting grep find preferences
              app.findGrepPreferences.properties = {
              allowArbitraryHyphenation:true,
              findWhat:".+",
              //Finding texts with static properties
              texts = doc.findGrep();
              n = texts.length;
              //Looping through found texts to inspect further properties with values ranges.
              while ( n--  ) {
              nthText = texts[n];
              if ( nthText.pointSize <= 10.5
              // && nthText "other property"…
              // Now it's your turn to do the dirty work ;)
              //Applying style
              nthText.appliedParagraphStyle = myParaStyle;
              //reverting UI values in the F/C panel
              app.findGrepPreferences.properties = fgp;
              var u;
              app.doScript ( "main()",u,u,UndoModes.ENTIRE_SCRIPT, "The Script" );
              HTH
              Loic
              • 4. Re: Apply Paragraph Styles Depending on Text Values
                Hi Loic!
                I start to with your code. Look my file is very simple. But when I run the script the style Text Old didn't change to the style Text New
                At the moment, I only modify this line:
                paraStyleName = "Text New";
                Thanks so much!
                • 5. Re: Apply Paragraph Styles Depending on Text Values
                  Some other settings may corrupt the lookup process. Let's try resetting any existing props:
                  //MAIN FUNCTION
                  //VARS
                  if ( !doc ) {
                  return;
                  app.findGrepPreferences = null;
                  findWhat:".+",
                  n = texts.length;
                  while ( n--  ) {
                  nthText = texts[n];
                  //Applying style
                  var u;
                  • 6. Re: Apply Paragraph Styles Depending on Text Values
                    Hi Loic!
                    the code you added haven't any changes. I compare both and are the same, is not working
                    thanks you!
                    • 7. Re: Apply Paragraph Styles Depending on Text Values
                      You may have missed line #22:
                      The fact the code doesn't work may imply some F/C settings exclude the text from match. Is the hyphenation turned off on your text. Send your file if needed.
                      • 8. Re: Apply Paragraph Styles Depending on Text Values
                        Hi Loic!
                        thanks por the line. But the script don't do nothing.
                        Please look, this is my styles:
                        And I add my custom style in the line #8:
                        I use Adobe Indesign CC 2018.
                        Here are my indesign File: Download
                        Thanks for your patience!
                        • 9. Re: Apply Paragraph Styles Depending on Text Values
                          My bad, here is the fix :
                          //MAIN FUNCTION
                          //VARS
                          if ( !doc ) {
                          return;
                          findWhat:".+",
                          n = texts.length;
                          while ( n--  ) {
                          nthText = texts[n];
                          if ( !nthText.hyphenation
                          //Applying style
                          var u;
                          • 10. Re: Apply Paragraph Styles Depending on Text Values
                            Hi Loic,
                            I am sorry, I try several times your new code, but still not working.
                            Thank you!
                            • 11. Re: Apply Paragraph Styles Depending on Text Values
                              At this point, it doesn't make much sense. I tried to download your file but it went corrupted. May you send it as idml ?
                              • 12. Re: Apply Paragraph Styles Depending on Text Values
                                Hi Loic,
                                I upload again the files, and include the idml:
                                Download
                                • 13. Re: Apply Paragraph Styles Depending on Text Values
                                  Just turn hyphenation off in your sample and the scripts works fine as it's a requirement…
                                  if ( !nthText.hyphenation…
                                  • 14. Re: Apply Paragraph Styles Depending on Text Values
                                    Hi Loic,
                                    amazing! the script start to work. Now I try to add more styles, but I get a error. Is correct my new code?
                                    I added the lines #2 and #4:
                                        texts2 = [], n = 0, nthText2, myParaStyle2,
                                        paraStyleName2 = "Quotation New";
                                    also line #23:
                                        myParaStyle2 = doc.paragraphStyles.item ( paraStyleName2 );
                                        if ( !myParaStyle2.isValid ) myParaStyle2 = doc.paragraphStyles.add ( paraStyleName2 );
                                    also line #54:
                                        if ( !nthText2.hyphenation
                                            && nthText2.pointSize <= 10.5
                                            && fontStyle == "Italic"
                                            //Applying style
                                            nthText2.appliedParagraphStyle = myParaStyle2;
                                    FULL CODE:
                                    //MAIN FUNCTION
                                        //VARS
                                        if ( !doc ) {
                                        return;
                                        findWhat:".+",
                                        n = texts.length;
                                        while ( n--  ) {
                                        nthText = texts[n];
                                        nthText2 = texts2[n];
                                        && nthText.pointSize <= 10.5
                                        //Applying style
                                            //Applying style
                                        var u;
                                    This is my new styles, I upload my indesign files.
                                    Look:
                                    Thank you!
                                    • 15. Re: Apply Paragraph Styles Depending on Text Values
                                      //MAIN FUNCTION
                                          //VARS
                                          if ( !doc ) {
                                          return;
                                          findWhat:".+",
                                          n = texts.length;
                                          while ( n--  ) {
                                          nthText = texts[n];
                                                  if ( nthText.fontStyle == "Italic" ) {
                                      nthText.appliedParagraphStyle = myParaStyle2;
                                      else {
                                          //Applying style
                                          var u;
                                      • 16. Re: Apply Paragraph Styles Depending on Text Values
                                        Hi Loic!
                                        I am very happy because your script is working
                                        Now I start to test deeply, and I find some obstacle, please can you help me?
                                        Like you can see my Styles to apply are inside a folders:
                                        To fix this, I did this:
                                            paraStyleName = doc.paragraphStyleGroups.itemByName("TEXT NEW").paragraphStyles.itemByName("Text New");
                                            paraStyleName2 = doc.paragraphStyleGroups.itemByName("QUOTATION NEW").paragraphStyles.itemByName("Quotation New");
                                        Why is not working?
                                        • 17. Re: Apply Paragraph Styles Depending on Text Values
                                          It's likely because script paraStyleName variable expects a string so it's used to target a specific style. In your case, you are passing a script reference so later on, the script tries to set a reference to a paragraph style based on a string which is actually a paragraph style instance.
                                          You need to rewrap the script so instead of passing a string, you can pass the style itself:
                                          var paraStyle = doc.paragraphStyleGroups.itemByName("TEXT NEW").paragraphStyles.itemByName("Text New");
                                          Then
                                          nthText.appliedParagraphStyle = paraStyle;
                                          • 18. Re: Apply Paragraph Styles Depending on Text Values
                                            Hi Loic, is working, you help me a lot really deep thank you!
                                            Download the files
                                            // The Script apply paragraph styles based in the text options. For example if your text are in bold, the script will apply the Paragraph Quotation Bold.
                                            // It is a easy way to typeset long documents with your custom styles.
                                            // Files to download: https://github.com/firedevelop/id0000013-Adobe-InDesign-Scripts-Examples/tree/master/id0000074-Apply-Paragraph-Styles-Depending-on-Text-Values
                                            // Thanks to the author: Loic.Aigon from Adobe Forums
                                            //MAIN FUNCTION
                                                //VARS
                                                texts3 = [], n = 0, nthText3, myParaStyle3,
                                                texts4 = [], n = 0, nthText4, myParaStyle4,
                                                paraStyleName2 = "Text New 12";
                                                paraStyleName3 = "Quotation New Bold";
                                                paraStyleName4 = "Quotation New Italic";
                                                if ( !doc ) {
                                                return;
                                                var paraStyle = doc.paragraphStyleGroups.itemByName("TEXT NEW").paragraphStyles.itemByName(paraStyleName);
                                                // if ( !myParaStyle.isValid ) myParaStyle = doc.paragraphStyles.add ( paraStyleName );
                                                var paraStyle2 = doc.paragraphStyleGroups.itemByName("TEXT NEW").paragraphStyles.itemByName(paraStyleName2);
                                                // if ( !myParaStyle2.isValid ) myParaStyle2 = doc.paragraphStyles.add ( paraStyleName2 );
                                                var paraStyle3 = doc.paragraphStyleGroups.itemByName("QUOTATION NEW").paragraphStyles.itemByName(paraStyleName3);
                                                myParaStyle3 = doc.paragraphStyles.item ( paraStyleName3 );
                                                // if ( !myParaStyle3.isValid ) myParaStyle3 = doc.paragraphStyles.add ( paraStyleName3 );
                                                var paraStyle4 = doc.paragraphStyleGroups.itemByName("QUOTATION NEW").paragraphStyles.itemByName(paraStyleName4);
                                                myParaStyle4 = doc.paragraphStyles.item ( paraStyleName4 );
                                                // if ( !myParaStyle4.isValid ) myParaStyle4 = doc.paragraphStyles.add ( paraStyleName4 );
                                                findWhat:".+",
                                                n = texts.length;
                                                while ( n--  ) {nthText = texts[n];
                                                    if (nthText.fontStyle =="Roman" && nthText.pointSize <= 10.5 ){nthText.appliedParagraphStyle = paraStyle;}
                                                    if (nthText.pointSize == 12){nthText.appliedParagraphStyle = paraStyle2;}
                                                    if (nthText.fontStyle == "Bold"){nthText.appliedParagraphStyle = paraStyle3;}
                                                    if (nthText.fontStyle == "Italic") {nthText.appliedParagraphStyle = paraStyle4;}
                                                var u;
                                            Some images about the script:
