I used to have two custom curve presets showing under the Linear, Medium Contrast, and Strong Contrast choices in the Point Curve dropdown menu. After updating to LR Classic 7.3 (macOS High Sierra 10.13.3), they are gone. As far as I can see, the files (.xmp) are still in their original directory (User/Library/Application Support/Adobe/Camera Raw/Curves) but they do not show up in the menu. Interestingly, I created a new custom curve profile in LR Classic 7.3, and that one shows up fine, and its corresponding .xmp file is in the above-mentioned directory, right next to the ones that do not show up. How do I get the old ones to show up?
I've just created a new Tone Curve Preset and it loads into User Library/Application Support/Adobe/CameraRaw/Curves
I've 2 other ones there from pre LR7 too, so it a bit strange that they're not loading.
Here's what I suggest: Move the files out of the Curves folder. Restart Lightroom. Move them back. Restart Lightroom again.
If it doesn't work I have an alternative suggestion.
Create a new Tone Curve preset-just make any random change to the curve and save it. Open a missing preset and the new
...Copy link to clipboard
Hi RafaelAviles,
This issue should be resolved in Lightroom 7.3.1 that went live today.
Please update Lightroom Classic CC to 7.3.1, click "Update" in the Creative Cloud desktop application next to Lightroom Classic CC. See Update Creative Cloud apps
Feel free to share your feedback with us.
Mohit
Mohit,
The update did not fix my problem. My curve presets are still missing from the dropdown menu in Curves. I do not even see a way to import them, or to create new ones. I am talking specifically about the Curves presets, not the Develop or Import presets.
Rafael
Hi Rafael,
Could you please share a screenshot of presets after expanding the curve presets.
Mohit
The “NewsReala” preset shown is one that I managed to create at some point after I first updated LR to 7.3.1 back in April. It is not the same as what I had before.
My settings are to have LR store presets in the Catalog. I can see the Develop Presets in a folder Lightroom>Lightroom Settings>Settings>User Presets, but I don’t see any of the Tone Curve Presets that I used to have.
After Lightroom 7.3.1 update, the presets location has changed to C:\Users\username\AppData\Roaming\Adobe\CameraRaw
And for curves, the location would be: C:\Users\username\AppData\Roaming\Adobe\CameraRaw\Curves
Mohit
Mohit,
As I stated in my original post, I am on a Mac computer (macOS High Sierra 10.13.3). What would be the locations in this case?
Rafael
Hi Rafael,
Please find the below location for Lightroom Classic CC (7.3.1) presets in mac.
User Library/Application Support/Adobe/Camera raw/settings/Users Presets
Mohit
Thank you Mohit. Unfortunately, that location does not have the Tone Curve Presets, only the Develop Presets. The old Tone Curve Presets are still in the User Library/Application Support/Adobe/CameraRaw/Curves folder and they have the .xmp extension, but they are not visible/available in the Tone Curve dropdown menu, as I have shown in the screen grab above.
How do i get LR to recognize/use those Tone Curve presets?
i have the same problem?
there is a solution?
thanks a lot
Create a new Tone Curve preset-just make any random change to the curve and save it. Open a missing preset and the new one in a text editor.
From the old one copy everything from
<rdf:Description
down to
</rdf:Description>
And then paste it in the same place in the new one, overwriting the settings. Save the file. Restart Lightroom.
Thanks, Sean. Creating a new Tone Curve preset and then modifying it as you suggests solved the problem for me.
I would like to point out that care must be taken when pasting the new section (<rdf:Description ... </rdf:Description>) into the new preset - there are several sections for the individual Tone Curves (R, G, B, and others) in the new presets. In my case, it only worked if I copied the old settings into the section that begins with <crs:ToneCurvePV2012>.
Rafael
