5 Replies Latest reply on May 14, 2018 1:14 PM by davidc19923048
    Export file to a certain folder
    flaviogomes_script Level 1
      var myFile = new File(String("PENTEFINO_" + app.activeDocument.name).replace(/\.indd$/i, ".txt"));
      if (File.fs == "Windows")
      var listFile = myFile.saveDlg("Save list", "Plain text file: *.txt" );
      else
      listFile = myFile.saveDlg("Save list");
      if (listFile != null)
      if (listFile.open("w"))
      listFile.encoding = "utf8"; //Codificando
      listFile.write(listFinal + "\r"); //Escrevendo o array salvo no TXT
      listFile.close(); //Fechando algum TXT aberto
      listFile.execute(); //Abrindo o TXT
      Hello friends, this is part of a script to generate a notepad with misspelled words.
      I would like that when exporting the .txt, I could choose a default folder to export.
      I count on the help of friends and I thank those who help.
        • 1. Re: Export file to a certain folder
          davidc19923048 Level 1
          Hello friend,
          You can get some default system folder by the class Folder (https://www.indesignjs.de/extendscriptAPI/indesign10/#Folder.html)
          Like
          Folder.desktop
          or
          Folder.myDocuments
          You can also create references to your folders with this class.
          Fico feliz por ver brasileiros =D
          • 2. Re: Export file to a certain folder
            Hi David, first of all sorry for the English, the Brazilians are increasingly making their presence here in the Forum, I am learning a lot here myself.
            As I told you, I am starting my studies in the script for Indesign, I would like your help to find a possible solution to my problem.
            I need to generate the ".txt" file by sending the export window to the following path:
            \\ 10.15.1.6 \ Editor \ _MATERIALS EDITOR 2019 \ EDICAO \ 02_FUND1 \ _TXT
            I took a look at what you sent me, as I said, I'm starting and I confess that I'm still a little lost in the documentation.
            How and where would I have to enter the command to open straight up this way?
            I would love to learn from you, all help will always be welcome, big hug.
            • 3. Re: Export file to a certain folder
              Flavio,
              I'm new in adobe scripting too, and the documentation is pretty bad.
              About your question:
              // always double the \ in windows
              var myFolder = new Folder ("\\\\10.15.1.6\\Editor\\_MATERIALS EDITOR 2019\\EDICAO\\02_FUND1\\_TXT\\");
              // here you can see if the folder exists, if true, it existis
              alert(myFolder.exists);
              // pointing the file to the folder above
              var myFile = new File(myFolder + String("PENTEFINO_" + app.activeDocument.name).replace(/\.indd$/i, ".txt"));
              please, test this.
              big hug
              • 4. Re: Export file to a certain folder
                davidc19923048, it worked perfectly, I just made some adjustments, because I was giving a bug in the final file name, it follows the complete code and it is working perfectly.
                Thanks for the help my friend.
                var myFolder = Folder ("/z/_MATERIAIS%20EDITORA%202019/EDICAO/02_FUND1/_TXT/PENTEFINO");
                var myFile = new File(myFolder + String("_" + app.activeDocument.name).replace(/\.indd$/i, ".txt"));
                else
                • 5. Re: Export file to a certain folder
                  flaviogomes_script, I'm happy to hear that.
                  best regards, friend
