var myFile = new File(String("PENTEFINO_" + app.activeDocument.name).replace(/\.indd$/i, ".txt"));
if (File.fs == "Windows")
var listFile = myFile.saveDlg("Save list", "Plain text file: *.txt" );
else
listFile = myFile.saveDlg("Save list");
if (listFile != null)
if (listFile.open("w"))
listFile.encoding = "utf8"; //Codificando
listFile.write(listFinal + "\r"); //Escrevendo o array salvo no TXT
listFile.close(); //Fechando algum TXT aberto
listFile.execute(); //Abrindo o TXT
Hello friends, this is part of a script to generate a notepad with misspelled words.
I would like that when exporting the .txt, I could choose a default folder to export.
I count on the help of friends and I thank those who help.
davidc19923048, it worked perfectly, I just made some adjustments, because I was giving a bug in the final file name, it follows the complete code and it is working perfectly.
Thanks for the help my friend.
...var myFolder = Folder ("/z/_MATERIAIS%20EDITORA%202019/EDICAO/02_FUND1/_TXT/PENTEFINO");
// pointing the file to the folder above
var myFile = new File(myFolder + String("_" + app.activeDocument.name).replace(/\.indd$/i, ".txt"));
Hello friend,
You can get some default system folder by the class Folder (https://www.indesignjs.de/extendscriptAPI/indesign10/#Folder.html)
Like
Folder.desktop
or
Folder.myDocuments
You can also create references to your folders with this class.
Fico feliz por ver brasileiros =D
Hi David, first of all sorry for the English, the Brazilians are increasingly making their presence here in the Forum, I am learning a lot here myself.
As I told you, I am starting my studies in the script for Indesign, I would like your help to find a possible solution to my problem.
I need to generate the ".txt" file by sending the export window to the following path:
\\ 10.15.1.6 \ Editor \ _MATERIALS EDITOR 2019 \ EDICAO \ 02_FUND1 \ _TXT
I took a look at what you sent me, as I said, I'm starting and I confess that I'm still a little lost in the documentation.
How and where would I have to enter the command to open straight up this way?
I would love to learn from you, all help will always be welcome, big hug.
Flavio,
I'm new in adobe scripting too, and the documentation is pretty bad.
About your question:
// always double the \ in windows
var myFolder = new Folder ("\\\\10.15.1.6\\Editor\\_MATERIALS EDITOR 2019\\EDICAO\\02_FUND1\\_TXT\\");
// here you can see if the folder exists, if true, it existis
alert(myFolder.exists);
var myFile = new File(myFolder + String("PENTEFINO_" + app.activeDocument.name).replace(/\.indd$/i, ".txt"));
please, test this.
big hug
else
flaviogomes_script, I'm happy to hear that.
best regards, friend
