I opened a project edited in PP ver 12 in the new ver 12.1 and all clips in a sequence that used the Rate Stretch Tool were altered.
Speed changed are applied but nothing is timed correctly it was okay in the last version of Premiere.
Does the media cached need resetting?
Bruce
It's always ok to dump the media cache/cache database files. Might fix this, so yea ... dump 'em.
Neil
I deleted media cache, media cache and peak files.
No change, timing still off.
Are you clear of this issue yet, McCabeImages? Let us know.
Kevin
Kevin,
I am still having this issue.
It affects segments in the timeline that have speed increases applied (with Rate Stretch tool) and freeze frame segments.
Since my original posting I have discovered that most of these errors can be fixed with the Slip tool (moving and still segments.) But it's a huge amount of work as a program may have hundreds of the edits.
Does this issue appear in any bug reports?
Bruce
