Every time I attempt to open a PDF within Outlook I am prompted with a box asking "How do you want to open this file?" I choose Adobe Acrobat DC and check the box that says Always use this app to open .pdf files and OK. The next time I attempt to open the PDF it does the same thing. I am able to open PDF's but I'm not sure why I continue to get prompted.
I am using Adobe Creative Cloud. Also, I have already made Adobe Acrobat DC my default program outside of Outlook to open PDF's and I am never prompted when I just try to open a saved file.
Bueller?
You may blame Microsoft for this. Apparently, their Windows OS group believes that they have the responsibility to make sure that you know that they have some other software that Microsoft prefers you use to open a particular file type.
This problem is not confined to .pdf but you will also find it for .jpg, .tif, and .png file types normally associated with Photoshop. Nor is it limited to Adobe products. You will find the same interference by Microsoft for music file types such as .mp3, .mp4, and .wav if you are trying to use iTunes from Apple.
Typically this issue is seen after any and all Microsoft OS updates such as the typical “patch Tuesday” updates (now occurring anytime). The above dialog appears usually after the first time you try to access a particular file type after the OS update the Always use this app to open option, that normally stops the obnoxious behaviour until the next OS upgrade/update.
Sorry that we can't be of further assistance with this. Complain vociferously to Microsoft on their forums. Maybe they might listen!
- Dov
Hi Dov,
Any update on this? I understand the "Patch Tuesday" and the fact that you said other files/programs experience the same issue, however, we have only one user (our CEO) that is experiencing this issue. She is only getting prompted when opening Adobe docs too, specifically PDF.
Best Regards,
Matt
So this is OBVIOUSLY a Windows issue. Why are you complaining to Adobe about Windows? Acrobat works fine right? Microsoft Windows just prompted you to ask if you wanted to use a different app to open the pdf. Obviously, you would not have installed Acrobat DC if you didn't want to use it.
This is a Microsoft marketing ploy that they decided to corrupt their operating system with, and nothing more.
Other Microsoft marketing driven OS corruption is the incessant opening of MSN.com in your default web browser. Another one is every time there is a feature update all your application defaults are reset. Your default web browser and pdf application will default to Microsoft Edge browser. This happens twice a year as a plan.
