2
Brush Pressure in Flash CC
Jul 01, 2013 Jul 01, 2013
So I've installed Flash Professional CC and honestly I'm enjoying so far, although there are some features that didn't please me like slow respond when using brush when using Cintiq 13HD. I also noticed that when I use the brush with Cintiq, the button for brush pressure is missing. I need to know how can I enable brush pressure in Flash CC. Any idea?
Thanks.
Mohammad Ahmed Fikree
Performance , Product issue
57.2K
Community Beginner , Mar 07, 2016 Mar 07, 2016
Actually never mind I've solved the problem apparently. In case anyone else has similar problems here's what I did:
1 go to Control Panel>Administrative tools>Services
2 find Tablet PC Input Service
3 right click and select Stop
(optional)
4. double click Tablet PC Input Service
5. go to Startup Type and select Disable or Manual.
This made the Use Pressure function suddenly appear and it works like a charm.
Pressure and tilt options for brush do not come up till you place your pen on the tablet and click on the stage.Once clicked they start appearing ,sometimes these options are hidden, you can resize your tools panel to see the options.And slow response is a known issue and we are tracking it.You can refer to this thread for more details :http://forums.adobe.com/message/5454376#5454376.
-Sangeeta
Mar 05, 2015 Mar 05, 2015
pressure sensitivity icon shows up but line remains unchanged in thickness-despite pressure applied
Adobe Employee ,
Mar 06, 2015 Mar 06, 2015
Hi Patrick,
Can you please post your flash pro version/ OS/ machine/ graphic tablet/ tablet driver version details?
Mohan
Jun 13, 2015 Jun 13, 2015
Having the same issue here
I'm using:
Window 7
Flash CC Version 2.1.0.108
Wacom Intous 5
Wacom driver 6.3.11-4a
Adobe Employee ,
Jun 14, 2015 Jun 14, 2015
Hi ,
The version which you have mentioned above is Creative Cloud Version , can you please let us know the Flash Application Version from About Flash screen?
Latha
Hi, I'm using Flash CC 14.2.0.20
Managed to find the solution myself... by getting a legacy version Wacom driver.
Adobe Employee ,
Hi ,
That's great ,but  if it is working with legacy drivers it should work with latest drivers also . your latest drivers might get corrupted ,can you please uninstall the present drivers and install latest drivers and try once ?because if installed drivers are corrupted we would face this issues some times .
Latha
Adobe Employee ,
Jul 08, 2015 Jul 08, 2015
Hi Mohammad,
Please refer to the following documentation from Microsoft : Troubleshoot Microsoft Surface Pen for Surface Pro 3 and Surface 3
Akshay
Nov 26, 2015 Nov 26, 2015
I am seeing this problem in Windows 10 recently.
Win 10
Flash CC 15.0.1.179
Wacom Cintiq 13HD (monitor ...not tablet)
Wacom Driver 6.3.15-1
The problem is ONLY with Flash. The pressure is recognized in the Wacom callibration tool and in all other programs.
Dec 02, 2015 Dec 02, 2015
I was able to fix this by restarting my Wacom driver in Services. Both icons now appear.
However, I just purchased a Surface Pro 3 and cannot get either function to appear while using Flash.
Adobe Employee ,
Flash CC uses Wintab driver to detect a pressure and surface pro doesn't comes up with a pre-installed Wintab drivers.
To install the Wintab driver for Surface Pro 3:
1. Open your browser and go to the Surface software, firmware, and drivers page on the Microsoft Download Center.
2. Select Download.
3. Scroll to the bottom of the list, select the checkbox for the .zip file that starts with Wintab, and select Next.
4. Select Open.
5. Extract the files from the .zip file, double-click to run the file WinTab_Setup_x64.exe, and follow the on-screen instructions to complete the installation.
Mohan
Great! This worked. Thank you for your help Mohan!
Steven
How about for a cintiq?
To make them appear with my Cintiq, I went to services, and restarted the Wacom Professional service driver. Then restarted Flash.
I'm using Windows 10 and a 22HD Cintiq.
I tried that already. It didnt work.
I get either a super thin line or the thickness of the brush. Never the variable thickness.
I am not sure if this is relevant or not to the cause. I uninstalled and reinstalled the wacom drivers. Then I opted NOT to calibrate the cintiq. Now the pressure sensitivity is working again.
Apr 28, 2017 Apr 28, 2017
Thank you! Thank you! Thank you! My son has been searching high and low....and this fix it. Pressure sensitivity appeared immediately!
Dec 06, 2015 Dec 06, 2015
This is ridiculous.  I've had this problem on multiple computers and multiple tablets.  This is a common legacy issue that has yet to be formally addressed by Adobe's Flash team.  By contrast, I've never encountered this on any version of Photoshop.
Jan 06, 2016 Jan 06, 2016
I have tried everything above, Still got no pen pressure.
This seems like being a Flash bug only, as every other software (also Adobe Photoshop) works.
PLEASE FIX THIS ADOBE, -otherwise you have got a useless software for drawing/animating..
Cintiq 27QHD Creative Pen Display,
Windows 7,
Adobe Flash CC 2015
Jan 14, 2016 Jan 14, 2016
hi,
Same problem : no pen pressure
So i'm waiting for animate CC...
Cintiq 27qhd
Windows 10
Flash CC 2015
Engaged ,
Feb 24, 2016 Feb 24, 2016
Animate CC doesn't seem to have brush pressure either.
Feb 03, 2016 Feb 03, 2016
I'm still having this issue with a Wacom Pro 4. Please fix!
Same problem here... No brush pressure options available, Windows 10 and a 22HD Cintiq. None of the above suggestions worked. Any other suggestions please? I got work to do!
Did you look at the article in answer 8?
