Hello, there.
There is a way to get colorValue for the color picker selected color?
Oh, there is a way as well. It should be the last color added in the colors array you get with:
var colors = app.documents[0].colors.everyItem().getElements();
var lastColorAdded = colors[colors.length-1];
FWIW: This color has no name.
Uwe
var color = "#"+($.colorPicker ().toString(16) );
function hexToRgb(hex) {
var result = /^#?([a-f\d]{2})([a-f\d]{2})([a-f\d]{2})$/i.exec(hex);
return result ? {
r: parseInt(result[1], 16),
g: parseInt(result[2], 16),
b: parseInt(result[3], 16)
} : null;
alert( hexToRgb(color).toSource() );
Doesn't worked for what I need.
Maybe I'm not clear in my original post.
When the user uses the "eyedropper tool" to select a color, this color fills the swatch panel selected fill or stroke color.
I need to get the value of that color. The one that fills, for example, the "fill square" in swatches panel.
I'm sorry to not be clear enought.
And thanks for your help, Löic.
one could add a rectangle to the page and check fillColor or strokeColor properties:
colorValue, model and space .
Uwe
Thank you guys!
That's my fear. No way to get directly from fill square from swatches panel.
Thanks, Löic and Uwe!
Uwe
Awesome. That's exactly what I need. Thank you so much, Uwe!
Kind regards from Brazil.
My bad, I saw a post dealing with colorPicker and my brain made a connection
I think Laubender​ said it all.
