Hi all,
We are automating the dropbox sync to AEM where multiple assets at an go published to Scene7. We have configured the Max parallel jobs to be the number of cores -1 . We need to do batch workflows suppose only after completing the 500 workflows, another set of 500 DAM Update Asset should be run from the code. Is there any way to achieve this?
Sindhu.
Solved! Go to Solution.
Total Likes
Total Likes
Total Likes
Check with the Eng team that relied:
I expect that the dropbox sync is a custom component, so it would be the place to have the batching logic. The way it determined how many workflows were completed might be a bit tricky due to the multithreaded nature, but should not be hard maybe have a process step to set some property (synchronized) and check the value. This really has nothing to do with workflow as such.
Total Likes
Hi Scott,
Thanks for the reply. How could we determine the number of workflows which are running at a particular time. Appreciate your help here.
Sindhu.
Total Likes
You can determine the running WF instances here:
Hope this helps...
Total Likes
