I didn't manage to try puppet warp because since the release it's been greyed out.
premise: I use photoshop to work, so skip the part of tips like "unlock the level" or "select before transforming". Take for granted that puppet warp does not work because of some software problem.
I tried everything, update drivers, update software, smart objects etc.: simply no way.
The GPU acceleration is ON atm, but even if i switch it off, it won't change a thing.
Hi
You are shown as having two GPUs (Intel and NVIdia) which will have different drivers. This is known to cause issues with Photoshop. Photoshop works well with multiple monitors (I use three) provided those monitors are driven by a single GPU.
See sections 7 and 8 here:
Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
Dave
You have provided insufficient data to verify your claim.
What are the image’s Color Mode and bit depth?
Could you please post a screenshot with the pertinent Panels (Layers, Channels, Options Bar, …) and dialog visible?
Color Mode RGB. I tried every bit depth, it doesn't work for 8-16-32.
What you need in the Layer and channels panels?
Could you please post a screenshot with the pertinent Panels (Layers, Channels, Options Bar, …) and the menu visible?
What you mean with that? Sorry for asking, English is not my primary language, so maybe I don't understand what you're asking.
I meant that menu:
Have you tried the various settings under Photoshop CC > Preferences > Performance > Graphics Processor Settings > Advanced Settings (while restarting Photoshop after each change)?
Just to make sure: Have you deselected (cmd-D) yet?
I tried with both selected and not-selected item. No way unfortunately
Sorry, »selected« is a bit ambiguous here: One Layer needs to be selected, but no Selection should be active (Select > Deselect).
Yeah I mean I tried with and without an active selection on an active layer.
Have you tried the various »Drawing Mode« settings under Photoshop CC > Preferences > Performance > Graphics Processor Settings > Advanced Settings (while restarting Photoshop after each change)?
Hi
Can you go to Photoshop Help >System Info and click on the "copy" button . Then paste the info here. It may help us see what is preventing the GPU functions on your set up.
Dave
Here Dave!
And thanks.
P.S: Not only Puppet Warp, Liquify doesn't work too, even 3D functions don't work as well, because some OpenGL document error if I remember well.
Adobe Photoshop Version: 19.1.4 20180507.r.325 2018/05/07: 1170750 x64
Number of Launches: 57
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.16299.431
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Physical processor count: 4
Processor speed: 3500 MHz
Built-in memory: 32653 MB
Free memory: 17414 MB
Memory available to Photoshop: 29366 MB
Memory used by Photoshop: 70 %
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
Display: 2
Display Bounds: top=0, left=-2560, bottom=1440, right=0
OpenGL Drawing: Disabled.
OpenGL Allow Old GPUs: Not Detected.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=2
NumCLGPUs=2
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=4096
glgpu[0].GLName="NVIDIA GeForce GTX 970"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="24.21.13.9731"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="GeForce GTX 970/PCIe/SSE2"
glgpu[0].GLRendererID=5058
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_desktop_ref4i.inf_amd64_5e0f3147a308ab3d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_desktop_ref4i.inf_amd64_5e0f3147a308ab3d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_desktop_ref4i.inf_amd64_5e0f3147a308ab3d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_desktop_ref4i.inf_amd64_5e0f3147a308ab3d\nvldumdx.dll"
glgpu[0].GLDriverDate="20180422000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2 "
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=1629
clgpu[0].CLName="Intel(R) HD Graphics 4600"
clgpu[0].CLVendor="Intel(R) Corporation"
clgpu[0].CLVendorID=32902
clgpu[0].CLDriverVersion="20.19.15.4835"
clgpu[0].CLBandwidth=1.47498e+10
clgpu[0].CLCompute=183.494
glgpu[1].GLVersion="4.1"
glgpu[1].IsIntegratedGLGPU=1
glgpu[1].GLMemoryMB=2048
glgpu[1].GLName="Intel(R) HD Graphics 4600"
glgpu[1].GLVendor="NVIDIA Corporation"
glgpu[1].GLVendorID=32902
glgpu[1].GLDriverVersion="20.19.15.4835"
glgpu[1].GLRectTextureSize=16384
glgpu[1].GLRenderer="GeForce GTX 970/PCIe/SSE2"
glgpu[1].GLRendererID=1042
glgpu[1].HasGLNPOTSupport=1
glgpu[1].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll"
glgpu[1].GLDriverDate="20171016000000.000000-000"
glgpu[1].CanCompileProgramGLSL=1
glgpu[1].GLFrameBufferOK=1
glgpu[1].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
glgpu[1].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[1].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[1].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[1].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[1].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[1].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[1].CLPlatformVersion="1.2"
clgpu[1].CLDeviceVersion="1.2 CUDA"
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=4096
clgpu[1].CLName="GeForce GTX 970"
clgpu[1].CLVendor="NVIDIA Corporation"
clgpu[1].CLVendorID=4318
clgpu[1].CLDriverVersion="397.31"
clgpu[1].CLBandwidth=1.4514e+11
clgpu[1].CLCompute=1503.31
License Type: Subscription
Serial number: 96040480527323851653
GUIDBucket:
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Temporary file path: C:\Users\Daddy\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
F:\, 1,82T, 1,38T free
D:\, 3,64T, 964,9G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/11/22-18:28:12 79.589342 79.589342
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2017/10/31-06:12:59 79.250229 79.250229
AdobePIP.dll Adobe Product Improvement Program 7.4.1.109.46827
AdobeSVGAGM.dll AdobeSVGAGM 79.588619 79.588619
AdobeXMP.dll Adobe XMP Core 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPFiles.dll Adobe XMP Files 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPScript.dll Adobe XMP Script 2017/07/13-01:06:39 79.160924 79.160924
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/11/22-18:28:12 79.589342 79.589342
ahclient.dll AdobeHelp Dynamic Link Library 3.0.0.6
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8) 1.000000
ARE.dll ARE 2017/11/22-18:28:12 79.589342 79.589342
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/11/22-18:28:12 79.589342 79.589342
BIBUtils.dll BIBUtils 2017/11/22-18:28:12 79.589342 79.589342
boost_date_time.dll photoshopdva 11.1.0
boost_filesystem.dll photoshopdva 11.1.0
boost_signals.dll photoshopdva 11.1.0
boost_system.dll photoshopdva 11.1.0
boost_threads.dll photoshopdva 11.1.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/11/22-18:28:12 79.589342 79.589342
CRClient.dll Adobe Crash Reporter Client DLL 1.6.3.0
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 11.1.0
dvacore.dll photoshopdva 11.1.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 11.1.0
dvamediatypes.dll photoshopdva 11.1.0
dvametadata.dll photoshopdva 11.1.0
dvametadataapi.dll photoshopdva 11.1.0
dvametadataui.dll photoshopdva 11.1.0
dvaplayer.dll photoshopdva 11.1.0
dvatransport.dll photoshopdva 11.1.0
dvaui.dll photoshopdva 11.1.0
dvaunittesting.dll photoshopdva 11.1.0
dynamiclink.dll photoshopdva 11.1.0
ExtendScript.dll ExtendScript 2017/08/31-12:13:14 81.1150526 81.1150526
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.22
JP2KLib.dll JP2KLib 2017/10/31-01:22:04 79.268591 79.268591
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
LogSession.dll LogSession 7.4.1.109.46827
mediacoreif.dll photoshopdva 11.1.0
MPS.dll MPS 2017/10/31-01:22:04 79.588396 79.588396
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2018 19.1.4
Plugin.dll Adobe Photoshop CC 2018 19.1.4
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 8.5.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 8.5.0.87
PSArt.dll Adobe Photoshop CC 2018 19.1.4
PSCloud.dll 1.0.0.1
PSViews.dll Adobe Photoshop CC 2018 19.1.4
SCCore.dll ScCore 2017/08/31-12:13:14 81.1150526 81.1150526
SVGRE.dll SVGRE 79.586793 79.586793
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
tbb.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WinRTSupport.dll Adobe Photoshop Windows RT Support 19.0.0.0
WRServices.dll WRServices Thu June 21 2017 12:26:24 Build 0.22473 0.22473
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
Accented Edges 19.1.4 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 19.1.4 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 19.1.4 - from the file “Filter Gallery.8bf”
Average 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Average.8bf”
Bas Relief 19.1.4 - from the file “Filter Gallery.8bf”
BMP 19.1.4 - from the file “Standard MultiPlugin.8bf”
Camera Raw 10.3 - from the file “Camera Raw.8bi”
Camera Raw Filter 10.3 - from the file “Camera Raw.8bi”
Chalk && Charcoal 19.1.4 - from the file “Filter Gallery.8bf”
Chrome 19.1.4 - from the file “Filter Gallery.8bf”
Cineon 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Cineon.8bi”
Clouds 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Clouds.8bf”
Collada 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
Color Halftone 19.1.4 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 19.1.4 - from the file “Filter Gallery.8bf”
CompuServe GIF 19.1.4 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 19.1.4 - from the file “Filter Gallery.8bf”
Craquelure 19.1.4 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 19.1.4 - from the file “Standard MultiPlugin.8bf”
Crosshatch 19.1.4 - from the file “Filter Gallery.8bf”
Crystallize 19.1.4 - from the file “Standard MultiPlugin.8bf”
Cutout 19.1.4 - from the file “Filter Gallery.8bf”
Dark Strokes 19.1.4 - from the file “Filter Gallery.8bf”
De-Interlace 19.1.4 - from the file “Standard MultiPlugin.8bf”
Dicom 19.1.4 - from the file “Dicom.8bi”
Difference Clouds 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Clouds.8bf”
Diffuse Glow 19.1.4 - from the file “Filter Gallery.8bf”
Displace 19.1.4 - from the file “Standard MultiPlugin.8bf”
Dry Brush 19.1.4 - from the file “Filter Gallery.8bf”
Eazel Acquire 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “EazelAcquire.8ba”
Entropy 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
Export Color Lookup Tables 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Export3DLUT.8be”
Extrude 19.1.4 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “FastCore.8bx”
Fibers 19.1.4 - from the file “Standard MultiPlugin.8bf”
Film Grain 19.1.4 - from the file “Filter Gallery.8bf”
Filter Gallery 19.1.4 - from the file “Filter Gallery.8bf”
Flash 3D 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
Fresco 19.1.4 - from the file “Filter Gallery.8bf”
Glass 19.1.4 - from the file “Filter Gallery.8bf”
Glowing Edges 19.1.4 - from the file “Filter Gallery.8bf”
Google Earth 4 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
Graphic Pen 19.1.4 - from the file “Filter Gallery.8bf”
Halftone Pattern 19.1.4 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “HalideBottlenecks.8bx”
HDRMergeUI 19.1.4 - from the file “HDRMergeUI.8bf”
HSB/HSL 19.1.4 - from the file “Standard MultiPlugin.8bf”
IFF Format 19.1.4 - from the file “Standard MultiPlugin.8bf”
IGES 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
Ink Outlines 19.1.4 - from the file “Filter Gallery.8bf”
JPEG 2000 19.1.4 - from the file “JPEG2000.8bi”
Kurtosis 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
Lens Blur 19.1.4 - from the file “Lens Blur.8bf”
Lens Correction 19.1.4 - from the file “Lens Correction.8bf”
Lens Flare 19.1.4 - from the file “Standard MultiPlugin.8bf”
Liquify 19.1.4 - from the file “Liquify.8bf”
Matlab Operation 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “ChannelPort.8bf”
Maximum 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
Mean 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
Measurement Core 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “MeasurementCore.8me”
Median 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
Mezzotint 19.1.4 - from the file “Standard MultiPlugin.8bf”
Minimum 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
MMXCore Routines 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “MMXCore.8bx”
Mosaic Tiles 19.1.4 - from the file “Filter Gallery.8bf”
Multiprocessor Support 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “MultiProcessor Support.8bx”
Neon Glow 19.1.4 - from the file “Filter Gallery.8bf”
Note Paper 19.1.4 - from the file “Filter Gallery.8bf”
NTSC Colors 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “NTSC Colors.8bf”
Ocean Ripple 19.1.4 - from the file “Filter Gallery.8bf”
OpenEXR 19.1.4 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 19.1.4 - from the file “Filter Gallery.8bf”
Palette Knife 19.1.4 - from the file “Filter Gallery.8bf”
Patchwork 19.1.4 - from the file “Filter Gallery.8bf”
Paths to Illustrator 19.1.4 - from the file “Standard MultiPlugin.8bf”
PCX 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “PCX.8bi”
Photocopy 19.1.4 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Photoshop3DEngine.8bi”
Photoshop Touch 19.0 - from the file “PSDX.8bi”
Picture Package Filter 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “ChannelPort.8bf”
Pinch 19.1.4 - from the file “Standard MultiPlugin.8bf”
Pixar 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Pixar.8bi”
Plaster 19.1.4 - from the file “Filter Gallery.8bf”
Plastic Wrap 19.1.4 - from the file “Filter Gallery.8bf”
PLY 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
Pointillize 19.1.4 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 19.1.4 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “PBM.8bi”
Poster Edges 19.1.4 - from the file “Filter Gallery.8bf”
PRC 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
Radial Blur 19.1.4 - from the file “Standard MultiPlugin.8bf”
Radiance 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Radiance.8bi”
Range 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
Render Color Lookup Grid 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Export3DLUT.8be”
Reticulation 19.1.4 - from the file “Filter Gallery.8bf”
Ripple 19.1.4 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 19.1.4 - from the file “Filter Gallery.8bf”
Save for Web 19.1.4 - from the file “Save for Web.8be”
ScriptingSupport 19.1.4 - from the file “ScriptingSupport.8li”
Shake Reduction 19.1.4 - from the file “Shake Reduction.8bf”
Shear 19.1.4 - from the file “Standard MultiPlugin.8bf”
Skewness 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
Smart Blur 19.1.4 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 19.1.4 - from the file “Filter Gallery.8bf”
Solarize 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Solarize.8bf”
Spaces 19.1.4 - from the file “Spaces.8li”
Spatter 19.1.4 - from the file “Filter Gallery.8bf”
Spherize 19.1.4 - from the file “Standard MultiPlugin.8bf”
Sponge 19.1.4 - from the file “Filter Gallery.8bf”
Sprayed Strokes 19.1.4 - from the file “Filter Gallery.8bf”
Stained Glass 19.1.4 - from the file “Filter Gallery.8bf”
Stamp 19.1.4 - from the file “Filter Gallery.8bf”
Standard Deviation 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
STL 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
Sumi-e 19.1.4 - from the file “Filter Gallery.8bf”
Summation 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
Targa 19.1.4 - from the file “Standard MultiPlugin.8bf”
Texturizer 19.1.4 - from the file “Filter Gallery.8bf”
Tiles 19.1.4 - from the file “Standard MultiPlugin.8bf”
Torn Edges 19.1.4 - from the file “Filter Gallery.8bf”
Twirl 19.1.4 - from the file “Standard MultiPlugin.8bf”
U3D 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
Underpainting 19.1.4 - from the file “Filter Gallery.8bf”
Vanishing Point 19.1.4 - from the file “VanishingPoint.8bf”
Variance 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
Water Paper 19.1.4 - from the file “Filter Gallery.8bf”
Watercolor 19.1.4 - from the file “Filter Gallery.8bf”
Wave 19.1.4 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
WIA Support 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “WIASupport.8li”
Wind 19.1.4 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “WBMP.8bi”
ZigZag 19.1.4 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins:
Lazy Nezumi Pro 17.10.20.1526 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\MouseHookPro64.8li”
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.13.141 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\purchaseStock.html”
Libraries 2.13.141 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\index.html”
com.adobe.inapp.typekit.purchase 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\purchaseTypekit.html”
Start 2.2.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.2.1\index.html?v=2.2.1.67”
Coolorus 2․5 2.5.12 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.moongorilla.coolorus2\index.html”
Export As 3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
com.adobe.Butler.backend 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
New Document 2.2.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.fnft-2.2.1\fnft.html?v=2.2.1.30”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Brusherator Preview 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.kritskiy.previewrator\index.html”
Brusherator 1.2.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.kritskiy.brusherator\index.html”
Prisma Palette Beta 5 0.1.0 - from the file “C:\Users\Daddy\AppData\Roaming\Adobe\CEP\extensions\com.colourconstructor.prismapalette\html\index.html”
Brusherator Plus 1.2.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.kritskiy.bt_a\index.html”
Installed TWAIN devices: NONE
Hi
Dave
Are you saying Puppet Warp is not available after putting the selected area on a transparent layer?
Yes, transparent layer, and no Puppet Warp available. I think it's something related to GPU acceleration as well as the AIF error during Liquify.
It seems to me like PS is not using my GPU even when I select the option in the Edit>Preferences window, and I don't know why, or how to fix it...
Copypaste from another thread:
"Ok, this is weird and I don't know how it worked, but it did.
After changing my setup from 3 to 2 monitors, it looks like for some error my PC assigned my integrated GPU to my Cintiq, or maybe Nvidia had troubles working with my tablet. I uninstalled the Nvidia GPU drivers completely and unplugged HDMI port cables, then reinstalled Nvidia Drivers, switched off and pluged back HDMI. After restarting and updating Windows 10 all is working.
I don't know if it was a software problem related to HDMI ports somehow, Nvidia, or...Maybe it's been some kind of black magic?
Thanks for the assistance tho.
The solution for my problem could be useful for all multiple monitor users (Wacom Tablets count): be sure to have your dedicated GPU assigned to both your monitors!
Thanks Ged Traynor and davescm
Yes - multiple monitors work well but multiple GPUs do not.
Glad you have it working now
Dave
