3 Replies Latest reply on May 17, 2018 8:36 AM by Loic.Aigon
    Find different text and apply different paragraph styles
    suresh0208 Level 1
      I have so many documents. Which style may be repeated, But not next after next.
      My requirement is:
      Step 1:
      Find Text Called "SECTION" in content and apply the style name called "Level-1";
      Step 2:
      Find Numbers started in content like "1.1, 1.2, 1.3 to 16.1, 16.2, 16.3 so on " and apply the style name called "Level-2";
      Step 3: Remaining text Should apply "Para";
      Step 4: In Paragraph if Tab(Space) Comes before that apply the charecter style called "Para Bold".
      Below is a sample example:
      I am very new to scripting. can any one help !
      Below the code i have tried and getting a error:
      var myDoc = app.activeDocument,
      myCodes = ["SECTION","Numbers"],
      C = myCodes.length,  c;
      app.findTextPreferences = null;
      for ( c = 0; c < C; c++) {
          app.findTextPreferences.findWhat = myCodes[c];
          myFound = myDoc.findText();
          var F = myFound.length,  f;
          var Style_01 = myDoc.paragraphStyleGroups.itemByName("INDEX").paragraphStyles.itemByName("Level-1");
          var Style_02 = myDoc.paragraphStyleGroups.itemByName("INDEX").paragraphStyles.itemByName("Level-2");
          for ( f = 0; f < F; f++) {
              myFound[f].appliedCharacterStyle = myDoc.characterStyles[0];
              if ((myFound[f].appliedParagraphStyle == Style_01) ||
                  (myFound[f].appliedParagraphStyle == Style_02) ||
                                  myFound[f].appliedParagraphStyle = MyStyle;
              } else{}
      //I have tried this script too but not understanding,
      var main = function() {
          //VARS
          var doc = app.properties.activeDocument,
          fgp = app.findGrepPreferences.properties,
          texts = [], n = 0, nthText, myParaStyle,
          texts2 = [], n = 0, nthText2, myParaStyle2,
          texts3 = [], n = 0, nthText3, myParaStyle3,
          texts4 = [], n = 0, nthText4, myParaStyle4,
          paraStyleName = "Text New";
          paraStyleName2 = "Text New 12";
          paraStyleName3 = "Quotation New Bold";
          paraStyleName4 = "Quotation New Italic";
          //Exit if no documents open
          if ( !doc ) {
          alert("You need an open document" );
          return;
          //Create ParaStyle if needed. Otherwise use it
          var paraStyle = doc.paragraphStyleGroups.itemByName("TEXT NEW").paragraphStyles.itemByName(paraStyleName);
          myParaStyle = doc.paragraphStyles.item ( paraStyleName );
          // if ( !myParaStyle.isValid ) myParaStyle = doc.paragraphStyles.add ( paraStyleName );
          var paraStyle2 = doc.paragraphStyleGroups.itemByName("TEXT NEW").paragraphStyles.itemByName(paraStyleName2);
          myParaStyle2 = doc.paragraphStyles.item ( paraStyleName2 );
          // if ( !myParaStyle2.isValid ) myParaStyle2 = doc.paragraphStyles.add ( paraStyleName2 );
          var paraStyle3 = doc.paragraphStyleGroups.itemByName("QUOTATION NEW").paragraphStyles.itemByName(paraStyleName3);
          myParaStyle3 = doc.paragraphStyles.item ( paraStyleName3 );
          // if ( !myParaStyle3.isValid ) myParaStyle3 = doc.paragraphStyles.add ( paraStyleName3 );
          var paraStyle4 = doc.paragraphStyleGroups.itemByName("QUOTATION NEW").paragraphStyles.itemByName(paraStyleName4);
          myParaStyle4 = doc.paragraphStyles.item ( paraStyleName4 );
          // if ( !myParaStyle4.isValid ) myParaStyle4 = doc.paragraphStyles.add ( paraStyleName4 );
          //Setting grep find preferences
          app.findGrepPreferences = null;
          app.findGrepPreferences.properties = {
          findWhat:".+",
          //Finding texts with static properties
          texts = doc.findGrep();
          n = texts.length;
          //Looping through found texts to inspect further properties with values ranges.
          while ( n--  ) {nthText = texts[n];
              if (nthText.fontStyle =="Roman" && nthText.pointSize <= 10.5 ){nthText.appliedParagraphStyle = paraStyle;}
              if (nthText.pointSize == 12){nthText.appliedParagraphStyle = paraStyle2;}
              if (nthText.fontStyle == "Bold"){nthText.appliedParagraphStyle = paraStyle3;}
              if (nthText.fontStyle == "Italic") {nthText.appliedParagraphStyle = paraStyle4;}
          //reverting UI values in the F/C panel
          app.findGrepPreferences.properties = fgp;
          var u;
          app.doScript ( "main()",u,u,UndoModes.ENTIRE_SCRIPT, "The Script" );
      Thanks in Advace
