How do I add a TextVariable to a TextFrame in InDesign?
I am creating the TextVariable like this.
var textVariable = app.activeDocument.textVariables.add({name: "My Name"});
I'm coming from Illustrator scripting where you have a content variable attached to each text frame object. I'm confused on how to link these text variables to text frames in InDesign.
Search inside forum, pretty certain there are dozens of samples.
Can you point me to one of those examples?
Sure :
Jongware already pointed to textVariableInstances with their method add().
See ExtendScript DOM documentation by Jongware here:
Adobe InDesign CS6 (8.0) Object Model JS: TextVariableInstance
Adobe InDesign CS6 (8.0) Object Model JS: TextVariableInstances
Adobe InDesign CS6 (8.0) Object Model JS: TextVariables
Also inspect this cornucopia of documentation also by Jongware:
Best,
Uwe
It is complicated – but that's because InDesign's text model is much more complicated than Illustrator's.
textVarR = app.selection[0].parentStory.textVariableInstances.add(LocationOptions.AFTER, app.selection[0]);
textVarR.associatedTextVariable = app.activeDocument.textVariables.item("My Name");
You insert a ("any", really) text variable code in your text, and then you associate it with the particular one you want.
Other than that, inserting the text variable in the proper place is pretty much the same as inserting text. You must provide a reference parent object – a plain text frame would not work, it needs a "text'-like object such as 'yourTextFrame.parentStory' – and "where" you want it to be inserted inside that parent object ("at the start", "at the end", or "before" or "after" a particular indexed element).
I tried your example but this is the error I get when I run your first line in ExtendScript with the text frame selected. I don't understand the error because it says TextFrame is an expected value.
Error: Invalid value for parameter 'reference' of method 'add'. Expected TextVariableInstance, TextFrame, EndnoteTextFrame, Story, XmlStory, Note, Cell, Footnote, Table, TextColumn, TextStyleRange, Text, InsertionPoint, Paragraph, Line, Word, Character or Change, but received TextFrame.
