Find different text and apply different paragraph styles
May 16, 2018 May 16, 2018
I have so many documents. Which style may be repeated, But not next after next.
My requirement is:
Step 1:
Find Text Called "SECTION" in content and apply the style name called "Level-1";
Step 2:
Find Numbers started in content like "1.1, 1.2, 1.3 to 16.1, 16.2, 16.3 so on " and apply the style name called "Level-2";
Step 3: Remaining text Should apply "Para";
Step 4: In Paragraph if Tab(Space) Comes before that apply the charecter style called "Para Bold".
Below is a sample example:
I am very new to scripting. can any one help !
Below the code i have tried and getting a error:
var myDoc = app.activeDocument,
myCodes = ["SECTION","Numbers"],
C = myCodes.length,  c;
app.findTextPreferences = null;
for ( c = 0; c < C; c++) {
    app.findTextPreferences.findWhat = myCodes;
    myFound = myDoc.findText();
    var F = myFound.length,  f;
    var Style_01 = myDoc.paragraphStyleGroups.itemByName("INDEX").paragraphStyles.itemByName("Level-1");
    var Style_02 = myDoc.paragraphStyleGroups.itemByName("INDEX").paragraphStyles.itemByName("Level-2");
    for ( f = 0; f < F; f++) {
        myFound.appliedCharacterStyle = myDoc.characterStyles[0];
        if ((myFound.appliedParagraphStyle == Style_01) ||
            (myFound.appliedParagraphStyle == Style_02) ||
                            myFound.appliedParagraphStyle = MyStyle;
        } else{}
//I have tried this script too but not understanding,
var main = function() {
    //VARS
    var doc = app.properties.activeDocument,
    fgp = app.findGrepPreferences.properties,
    texts = [], n = 0, nthText, myParaStyle,
    texts2 = [], n = 0, nthText2, myParaStyle2,
    texts3 = [], n = 0, nthText3, myParaStyle3,
    texts4 = [], n = 0, nthText4, myParaStyle4,
    paraStyleName = "Text New";
    paraStyleName2 = "Text New 12";
    paraStyleName3 = "Quotation New Bold";
    paraStyleName4 = "Quotation New Italic";
    //Exit if no documents open
    if ( !doc ) {
    alert("You need an open document" );
    return;
    //Create ParaStyle if needed. Otherwise use it
    var paraStyle = doc.paragraphStyleGroups.itemByName("TEXT NEW").paragraphStyles.itemByName(paraStyleName);
    myParaStyle = doc.paragraphStyles.item ( paraStyleName );
    // if ( !myParaStyle.isValid ) myParaStyle = doc.paragraphStyles.add ( paraStyleName );
    var paraStyle2 = doc.paragraphStyleGroups.itemByName("TEXT NEW").paragraphStyles.itemByName(paraStyleName2);
    myParaStyle2 = doc.paragraphStyles.item ( paraStyleName2 );
    // if ( !myParaStyle2.isValid ) myParaStyle2 = doc.paragraphStyles.add ( paraStyleName2 );
    var paraStyle3 = doc.paragraphStyleGroups.itemByName("QUOTATION NEW").paragraphStyles.itemByName(paraStyleName3);
    myParaStyle3 = doc.paragraphStyles.item ( paraStyleName3 );
    // if ( !myParaStyle3.isValid ) myParaStyle3 = doc.paragraphStyles.add ( paraStyleName3 );
    var paraStyle4 = doc.paragraphStyleGroups.itemByName("QUOTATION NEW").paragraphStyles.itemByName(paraStyleName4);
    myParaStyle4 = doc.paragraphStyles.item ( paraStyleName4 );
    // if ( !myParaStyle4.isValid ) myParaStyle4 = doc.paragraphStyles.add ( paraStyleName4 );
    //Setting grep find preferences
    app.findGrepPreferences = null;
    app.findGrepPreferences.properties = {
    findWhat:".+",
    //Finding texts with static properties
    texts = doc.findGrep();
    n = texts.length;
    //Looping through found texts to inspect further properties with values ranges.
    while ( n--  ) {nthText = texts;
        if (nthText.fontStyle =="Roman" && nthText.pointSize <= 10.5 ){nthText.appliedParagraphStyle = paraStyle;}
        if (nthText.pointSize == 12){nthText.appliedParagraphStyle = paraStyle2;}
        if (nthText.fontStyle == "Bold"){nthText.appliedParagraphStyle = paraStyle3;}
        if (nthText.fontStyle == "Italic") {nthText.appliedParagraphStyle = paraStyle4;}
    //reverting UI values in the F/C panel
    app.findGrepPreferences.properties = fgp;
    var u;
    app.doScript ( "main()",u,u,UndoModes.ENTIRE_SCRIPT, "The Script" );
Thanks in Advace
Scripting
740
People's Champ ,
May 17, 2018 May 17, 2018
Where is "MyStyle" referenced ?
And what kind of error do you get exactly ?
Hi Loic,
I really don't have idea. I have searched some topics in forum and try to edit that.
And the error i got is "Object Invalid".
If you can help in this that would be great.
People's Champ ,
there is probably more like the line number…
May 22, 2018 May 22, 2018
Hi Loic,
I am tried to edit a bit more and it is applying para style to text, But when i put a condition in text it's not working. When find text apply level-1 style. The updated codes as follows:
var myIndFile = File.openDialog ("Select Indesign File");
var myWordFile = File.openDialog ("Select Word File");
app.open (myIndFile);
var mydoc = app.activeDocument;
mydoc.textPreferences.smartTextReflow = true;
mydoc.textPreferences.limitToMasterTextFrames = false;
mydoc.textPreferences.deleteEmptyPages = false;
mydoc.textPreferences.addPages = AddPageOptions.endOfStory;
mydoc.pages.item(0).textFrames.item(0).place(File(myWordFile));
/*Style AREA*/
    try{
    myParagraphStyle = mydoc.paragraphStyles.item("Para");
    //If the paragraph style does not exist, trying to get its name will generate an error.
    myName = myParagraphStyle.name;
    catch (myError){
    //The paragraph style did not exist, so create it.
    myParagraphStyle = mydoc.paragraphStyles.add({name:"Para"});
/*End of Style AREA*/
    var myTextFrame = mydoc.pages.item(0).textFrames.item(0);
    myTextFrame.parentStory.texts.item(0).applyParagraphStyle(myParagraphStyle, true);
myCodes = ["SECTION"],
          if ((myFound.appliedParagraphStyle == myParagraphStyle) && (myFound == myCodes)) {
                            myFound.appliedParagraphStyle = Level1;
var wordName = myWordFile.name;
app.activeDocument.save(new File(myIndFile.path + "/"  +myIndFile.name.replace(".indd", "") + "_" +wordName+"_Spanish" + "_V1.0.indd"));
Line no : 21 to 55 needs some suggestions to edit.
My next task is find line starts with numbers chage to level-2 style.
Suresh.
