We have two URLs,
http://www.ontrenduniforms.com
and
http://www.thechefzone.com
that go to the same folder on the server. Other than the name and
header records, the two IIS entries are identical as are the DNS
entries. Since they share the same code, everything else is
identical: cfm pages, application.cfm included, and database.
Near the top of the page is a timing quantity. Click on "Chef
Coats" in the left menu and ontrenduniforms takes 20 times as long
to load as thechefzone. The second time both pages are almost
instantaneous. Ontrenduniforms will show a time that matches the
first timing for thechefzone while the chefzone goes to zero. The
third time, ontrenduniforms also goes to zero time.
Close the browser and do it again and the same thing happens
all over again. It also doesn't matter which order they are loaded
in.
We've placed the two domains in IIS in separate application
pools and they are now each running in a different CF instance.
That didn't help. There is nothing in the code that references the
url. In fact, the images are referencing a third domain that is
elsewhere. Hardly matters, since the difference in timing is during
the server side execution.
What would/is causing this to happen. Are there any known
issues?
