9 Replies Latest reply on May 17, 2018 10:03 AM by Laubender
    script imagecatalog.jsx don´t sorts images correctly
    Quato 240-LE
      Indesign mixes my images in a strange way, absolutely no order... I've got no idea what's wrong.
      My images have got the same amount of digits and are mixed in the contact sheet like: 00023, 00001, 00024, 00046, 00002 etc.
      Indesign CC 13.1 - Mac OS High Sierra 10.13.4
      Here is the responsible code of the image catalog script:
      function myWinOSFileFilter(myFolder){
        var myFiles = new Array;
        var myFilteredFiles = new Array;
        for(myExtensionCounter = 0; myExtensionCounter < myExtensions.length; myExtensionCounter++){
        myExtension = myExtensions[myExtensionCounter];
              myFiles = myFolder.getFiles("*"+ myExtension);
        if(myFiles.length != 0){
        for(var myFileCounter = 0; myFileCounter < myFiles.length; myFileCounter++){
        myFilteredFiles.push(myFiles[myFileCounter]);
        return myFilteredFiles;
      function myMacOSFileFilter(myFolder){
        var myFilteredFiles = myFolder.getFiles(myFileFilter);
      I am fuzzy about it..
        • 1. Re: script imagecatalog.jsx don´t sorts images correctly
          BarlaeDC Level 4
          Can you share the final document? ( using dropbox or similar service)
          Can you share a sample of the actual filenames including extension? Are you on wndows or mac ?
          Regards
          Malcolm
          • 2. Re: script imagecatalog.jsx don´t sorts images correctly
            Quato 240-LE Level 1
            #0001.jpg without letters in front doesn't work neither... .tif neither...
            • 3. Re: script imagecatalog.jsx don´t sorts images correctly
              Laubender Adobe Community Professional & MVP
              then you have to sort your image Array with a custom function that is working with the name of the files.
              Just tested the script on Windows 10. It's working as expected with a range of JPEG images named like yours.
              The case is different on Mac OS X. And it will be even more different with OS X High Sierra. I can remember a bug where the script files in the Scripts Panel are totally jumbled and not sorted alphabetically anymore due to a change Apple did when going from Sierra to High Sierra, I think.
              Search the forums and a thread comes up with some sorting suggestions here:
              imageCatalog image sorting before import
              Uwe
              1 person found this helpful
              • 4. Re: script imagecatalog.jsx don´t sorts images correctly
                A note to add: Alphabetical sorting of file names is not easy.
                array.sort() without a custom function as argument of method sort() is not the way to go. You can try it, it may better the situation, but it will not be perfect.
                EDIT: To make that clear, you have to sort after file names, not after files.
                Always a good read by Marc Autret:
                Indiscripts :: Alphabetical Sort in JavaScript (and InDesign)
                Uwe
                • 5. Re: script imagecatalog.jsx don´t sorts images correctly
                    Uwe
                  this unfortunately doesn't solve the problem... still consists the alternative ways neither
                  • 6. Re: script imagecatalog.jsx don´t sorts images correctly
                    I am a photographer ... no coder
                    • 7. Re: script imagecatalog.jsx don´t sorts images correctly
                      the ExtendScript below is an edited version of the original. It is tested on Windows 10 with InDesign CC 2018.1. I could not test it with InDesign on Mac OS X. That's your turn. I added a sort function for file names and implemented it. File name sorting may not be perfect, but sufficiant. The sorting algorithm is by Martin Fischer from www.hilfdirselbst.ch.
                      Here's the full code:
                      // EDITED BY UWE LAUBENDER
                      // ADDED: SORT FUNCTION.
                      // ImageCatalog-EDITED.jsx
                      // An InDesign CS6 JavaScript
                      @@@BUILDINFO@@@ ImageCatalog-EDITED.jsx !Version! Thu May 17 2018 17:59:52 GMT+0200
                      //Creates an image catalog from the graphic files in a selected folder.
                      //Each file can be labeled with the file name, and the labels are placed on
                      //a separate layer and formatted using a paragraph style ("label") you can
                      //modify to change the appearance of the labels.
                      //For more information on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
                      //Or visit the InDesign Scripting User to User forum at http://www.adobeforums.com .
                      //The myExtensions array contains the extensions of the graphic file types you want
                      //to include in the catalog. You can remove extensions from or add extensions to this list.
                      //myExtensions is a global. Mac OS users should also look at the file types in the myFileFilter function.
                      main();
                      function main(){
                          var myFilteredFiles;
                          //Make certain that user interaction (display of dialogs, etc.) is turned on.
                          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
                          myExtensions = [".jpg", ".jpeg", ".eps", ".ps", ".pdf", ".tif", ".tiff", ".gif", ".psd", ".ai"]
                          //Display the folder browser.
                          var myFolder = Folder.selectDialog("Select the folder containing the images", "");
                          //Get the path to the folder containing the files you want to place.
                          if(myFolder != null){
                                  if(File.fs == "Macintosh")
                                      // CHANGES BY UWE LAUBENDER :
                                      myFilteredFiles = myMacOSFileFilter(myFolder).sort( sortFileNames );
                                  else
                                      myFilteredFiles = myWinOSFileFilter(myFolder).sort( sortFileNames );
                                  if(myFilteredFiles.length != 0){
                                          myDisplayDialog(myFilteredFiles, myFolder);
                                          alert("Done!");
                      //Windows version of the file filter.
                      //Mac OS version of file filter
                      //Have to provide a separate version because not all Mac OS users use file extensions
                      //and/or file extensions are sometimes hidden by the Finder.
                      function myFileFilter(myFile){
                          var myFileType = myFile.type;
                          switch (myFileType){
                              case "JPEG":
                              case "EPSF":
                              case "PICT":
                              case "TIFF":
                              case "8BPS":
                              case "GIFf":
                              case "PDF ":
                                  return true;
                                  break;
                              default:
                              for(var myCounter = 0; myCounter<myExtensions.length; myCounter++){
                                  var myExtension = myExtensions[myCounter];
                                  if(myFile.name.indexOf(myExtension)>-1){
                                      return true;
                                      break;
                          return false;
                      function myDisplayDialog(myFiles, myFolder){
                          var myLabelWidth = 112;
                          var myStyleNames = myGetParagraphStyleNames(app);
                          var myLayerNames = ["Layer 1", "Labels"];
                          var myDialog = app.dialogs.add({name:"Image Catalog"});
                          with(myDialog.dialogColumns.add()){
                              with(dialogRows.add()){
                                  staticTexts.add({staticLabel:"Information:"});
                              with(borderPanels.add()){
                                  with(dialogColumns.add()){
                                          staticTexts.add({staticLabel:"Source Folder:", minWidth:myLabelWidth});
                                          staticTexts.add({staticLabel:myFolder.path + "/" + myFolder.name});
                                          staticTexts.add({staticLabel:"Number of Images:", minWidth:myLabelWidth});
                                          staticTexts.add({staticLabel:myFiles.length + ""});
                                      staticTexts.add({staticLabel:"Options:"});
                                          staticTexts.add({staticLabel:"Number of Rows:", minWidth:myLabelWidth});
                                          var myNumberOfRowsField = integerEditboxes.add({editValue:3});
                                          staticTexts.add({staticLabel:"Number of Columns:", minWidth:myLabelWidth});
                                          var myNumberOfColumnsField = integerEditboxes.add({editValue:3});
                                          staticTexts.add({staticLabel:"Horizontal Offset:", minWidth:myLabelWidth});
                                          var myHorizontalOffsetField = measurementEditboxes.add({editValue:12, editUnits:MeasurementUnits.points});
                                          staticTexts.add({staticLabel:"Vertical Offset:", minWidth:myLabelWidth});
                                          var myVerticalOffsetField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
                                      with (dialogRows.add()){
                                              staticTexts.add({staticLabel:"Fitting:", minWidth:myLabelWidth});
                                              var myFitProportionalCheckbox = checkboxControls.add({staticLabel:"Proportional", checkedState:true});
                                              var myFitCenterContentCheckbox = checkboxControls.add({staticLabel:"Center Content", checkedState:true});
                                              var myFitFrameToContentCheckbox = checkboxControls.add({staticLabel:"Frame to Content", checkedState:true});
                                              var myRemoveEmptyFramesCheckbox = checkboxControls.add({staticLabel:"Remove Empty Frames:", checkedState:true});
                                      staticTexts.add({staticLabel:""});
                              var myLabelsGroup = enablingGroups.add({staticLabel:"Labels", checkedState:true});
                              with (myLabelsGroup){
                                      //Label type
                                              staticTexts.add({staticLabel:"Label Type:", minWidth:myLabelWidth});
                                              var myLabelTypeDropdown = dropdowns.add({stringList:["File name", "File path", "XMP description", "XMP author"], selectedIndex:0});
                                      //Text frame height
                                              staticTexts.add({staticLabel:"Label Height:", minWidth:myLabelWidth});
                                              var myLabelHeightField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
                                      //Text frame offset
                                              staticTexts.add({staticLabel:"Label Offset:", minWidth:myLabelWidth});
                                              var myLabelOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
                                      //Style to apply
                                              staticTexts.add({staticLabel:"Label Style:", minWidth:myLabelWidth});
                                              var myLabelStyleDropdown = dropdowns.add({stringList:myStyleNames, selectedIndex:0});
                                      //Layer
                                              staticTexts.add({staticLabel:"Layer:", minWidth:myLabelWidth});
                                              var myLayerDropdown = dropdowns.add({stringList:myLayerNames, selectedIndex:0});
                              var myResult = myDialog.show();
                              if(myResult == true){
                                  var myNumberOfRows = myNumberOfRowsField.editValue;
                                  var myNumberOfColumns = myNumberOfColumnsField.editValue;
                                  var myRemoveEmptyFrames = myRemoveEmptyFramesCheckbox.checkedState;
                                  var myFitProportional = myFitProportionalCheckbox.checkedState;
                                  var myFitCenterContent = myFitCenterContentCheckbox.checkedState;
                                  var myFitFrameToContent = myFitFrameToContentCheckbox.checkedState;
                                  var myHorizontalOffset = myHorizontalOffsetField.editValue;
                                  var myVerticalOffset = myVerticalOffsetField.editValue;
                                  var myMakeLabels = myLabelsGroup.checkedState;
                                  var myLabelType = myLabelTypeDropdown.selectedIndex;
                                  var myLabelHeight = myLabelHeightField.editValue;
                                  var myLabelOffset = myLabelOffsetField.editValue;
                                  var myLabelStyle = myStyleNames[myLabelStyleDropdown.selectedIndex];
                                  var myLayerName = myLayerNames[myLayerDropdown.selectedIndex];
                                  myDialog.destroy();
                                  myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName);
                              else{
                                  myDialog.destroy();
                      function myGetParagraphStyleNames(myDocument){
                          var myStyleNames = new Array;
                          var myAddLabelStyle = true;
                          for(var myCounter = 0; myCounter < myDocument.paragraphStyles.length; myCounter++){
                              myStyleNames.push(myDocument.paragraphStyles.item(myCounter).name);
                              if (myDocument.paragraphStyles.item(myCounter).name == "Labels"){
                                  myAddLabelStyle = false;
                          if(myAddLabelStyle == true){
                              myStyleNames.push("Labels");
                          return myStyleNames;
                      function myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName){
                          var myPage, myFile, myCounter, myX1, myY1, myX2, myY2, myRectangle, myLabelStyle, myLabelLayer;
                          var myParagraphStyle, myError;
                          var myFramesPerPage = myNumberOfRows * myNumberOfColumns;
                          var myDocument = app.documents.add();
                          myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
                          myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
                          var myDocumentPreferences = myDocument.documentPreferences;
                          var myNumberOfFrames = myFiles.length;
                          var myNumberOfPages = Math.round(myNumberOfFrames / myFramesPerPage);
                          if ((myNumberOfPages * myFramesPerPage) < myNumberOfFrames){
                              myNumberOfPages++;
                          //If myMakeLabels is true, then add the label style and layer if they do not already exist.
                          if(myMakeLabels == true){
                              try{
                                  myLabelLayer = myDocument.layers.item(myLayerName);
                                  //if the layer does not exist, trying to get the layer name will cause an error.
                                  myLabelLayer.name;
                              catch (myError){
                                  myLabelLayer = myDocument.layers.add({name:myLayerName});
                              //If the paragraph style does not exist, create it.
                              try{
                                  myParagraphStyle = myDocument.paragraphStyles.item(myLabelStyle);
                                  myParagraphStyle.name;
                              catch(myError){
                                  myDocument.paragraphStyles.add({name:myLabelStyle});
                          myDocumentPreferences.pagesPerDocument = myNumberOfPages;
                          myDocumentPreferences.facingPages = false;
                          var myPage = myDocument.pages.item(0);
                          var myMarginPreferences = myPage.marginPreferences;
                          var myLeftMargin = myMarginPreferences.left;
                          var myTopMargin = myMarginPreferences.top;
                          var myRightMargin = myMarginPreferences.right;
                          var myBottomMargin = myMarginPreferences.bottom;
                          var myLiveWidth = (myDocumentPreferences.pageWidth - (myLeftMargin + myRightMargin)) + myHorizontalOffset
                          var myLiveHeight = myDocumentPreferences.pageHeight - (myTopMargin + myBottomMargin)
                          var myColumnWidth = myLiveWidth / myNumberOfColumns
                          var myFrameWidth = myColumnWidth - myHorizontalOffset
                          var myRowHeight = (myLiveHeight / myNumberOfRows)
                          var myFrameHeight = myRowHeight - myVerticalOffset
                          var myPages = myDocument.pages;
                          // Construct the frames in reverse order. Don't laugh--this will
                          // save us time later (when we place the graphics).
                          for (myCounter = myDocument.pages.length-1; myCounter >= 0; myCounter--){
                              myPage = myPages.item(myCounter);
                              for (var myRowCounter = myNumberOfRows; myRowCounter >= 1; myRowCounter--){
                                  myY1 = myTopMargin + (myRowHeight * (myRowCounter-1));
                                  myY2 = myY1 + myFrameHeight;
                                  for (var myColumnCounter = myNumberOfColumns; myColumnCounter >= 1; myColumnCounter--){
                                      myX1 = myLeftMargin + (myColumnWidth * (myColumnCounter-1));
                                      myX2 = myX1 + myFrameWidth;
                                      myRectangle = myPage.rectangles.add(myDocument.layers.item(-1), undefined, undefined, {geometricBounds:[myY1, myX1, myY2, myX2], strokeWeight:0, strokeColor:myDocument.swatches.item("None")});
                          // Because we constructed the frames in reverse order, rectangle 1
                          // is the first rectangle on page 1, so we can simply iterate through
                          // the rectangles, placing a file in each one in turn. myFiles = myFolder.Files;
                          for (myCounter = 0; myCounter < myNumberOfFrames; myCounter++){
                              myFile = myFiles[myCounter];
                              myRectangle = myDocument.rectangles.item(myCounter);
                              myRectangle.place(File(myFile));
                              myRectangle.label = myFile.fsName.toString();
                              //Apply fitting options as specified.
                              if(myFitProportional){
                                  myRectangle.fit(FitOptions.proportionally);
                              if(myFitCenterContent){
                                  myRectangle.fit(FitOptions.centerContent);
                              if(myFitFrameToContent){
                                  myRectangle.fit(FitOptions.frameToContent);
                              //Add the label, if necessary.
                                  myAddLabel(myRectangle, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, myLayerName);
                          if (myRemoveEmptyFrames == 1){
                              for (var myCounter = myDocument.rectangles.length-1; myCounter >= 0;myCounter--){
                                  if (myDocument.rectangles.item(myCounter).contentType == ContentType.unassigned){
                                      myDocument.rectangles.item(myCounter).remove();
                                  else{
                                      //As soon as you encounter a rectangle with content, exit the loop.
                                      break;
                      //Function that adds the label.
                      function myAddLabel(myFrame, myLabelType, myLabelHeight, myLabelOffset, myLabelStyleName, myLayerName){
                          var myDocument = app.documents.item(0);
                          var myLabel;
                          var myLabelStyle = myDocument.paragraphStyles.item(myLabelStyleName);
                          var myLabelLayer = myDocument.layers.item(myLayerName);
                          var myLink =myFrame.graphics.item(0).itemLink;
                          //Label type defines the text that goes in the label.
                          switch(myLabelType){
                              //File name
                              case 0:
                                  myLabel = myLink.name;
                                  break;
                              //File path
                              case 1:
                                  myLabel = myLink.filePath;
                                  break;
                              //XMP description
                              case 2:
                                  try{
                                      myLabel = myLink.linkXmp.description;
                                      if(myLabel.replace(/^\s*$/gi, "")==""){
                                          throw myError;
                                  catch(myError){
                                      myLabel = "No description available.";
                                  break;
                              //XMP author
                              case 3:
                                  try{
                                      myLabel = myLink.linkXmp.author
                                          throw myError;
                                  catch(myError){
                                      myLabel = "No author available.";
                                  break;
                          var myX1 = myFrame.geometricBounds[1];
                          var myY1 = myFrame.geometricBounds[2] + myLabelOffset;
                          var myX2 = myFrame.geometricBounds[3];
                          var myY2 = myY1 + myLabelHeight;
                          var myTextFrame = myFrame.parent.textFrames.add(myLabelLayer, undefined, undefined,{geometricBounds:[myY1, myX1, myY2, myX2], contents:myLabel});
                          myTextFrame.textFramePreferences.firstBaselineOffset = FirstBaseline.leadingOffset;
                          myTextFrame.parentStory.texts.item(0).appliedParagraphStyle = myLabelStyle;
                      // ADDED BY UWE LAUBENDER :
                      function sortFileNames( a,b )
                          // incoming a and b are files.
                          // We need strings to compare, not files!
                          a = a.name;
                          b = b.name;
                          // IDEA BY MARTIN FISCHER  FROM www.hilfdirselbst.ch
                          // http://www.martinfischer.de/
                          var myRegExp = new RegExp('^\\d+', );
                          var aObj = {num: a.match(myRegExp) != null ? a.match(myRegExp)[0] : '_', string: a.replace(/^\d+/, '')};
                          var bObj = {num: b.match(myRegExp) != null ? b.match(myRegExp)[0] : '_', string: b.replace(/^\d+/, '')};
                          // a and b are fully numeric :
                          if (aObj.string =='' && bObj.string == ''){ return a - b };
                          // the numeric parts of a and b are equal :
                          if (aObj.num == bObj.num ){ return aObj.string.toLowerCase() > bObj.string.toLowerCase() };
                          // the numeric part of a is greater than the numeric part of b :
                          if (aObj.num > bObj.num ){ return 1 };
                      Hope, it will work as expected on Mac OS X High Sierra.
                      Uwe
                      • 8. Re: script imagecatalog.jsx don´t sorts images correctly
                        Uwe, you are the man! Many thanks! It works! ... Testet with 555 photos
                        But I cannot believe, that I am the only person working with a Mac and High Sierra who needs this script. It was not easy to find a solution for me. Now its time for a beer - Prost!
                        • 9. Re: script imagecatalog.jsx don´t sorts images correctly
                          https://forums.adobe.com/people/Quato+240-LE  wrote
                          … Now its time for a beer - Prost!
                          Very good idea!
                          Beer gardens are open here in Würzburg.
                          I'm glad, it's working for you.
                          Best,
                          Uwe
