3 Replies Latest reply on Nov 15, 2018 5:12 AM by manuelb27477138
    Find the same page number in the same paragraph
    manuelb27477138 Level 1
      Hello everyone!
      in my Index texts one of common mistakes, are a duplicate page number in the same paragraph or page number and range that include the same page numbers.
      ¿is possible get an Alert with the problematic paragraph?
      For example, here are my 2 problems:
      1º the number 74 are inside the range between 70 and 75, then I need get an Alert.
      2º the number 7 appear 2 times, then I need get an Alert.
      Thanks so much in advance!
        • 1. Re: Find the same page number in the same paragraph
          Laubender Adobe Community Professional & MVP
          Hi Manuel,
          not exactly the thing you want, but very close.
          Marc Autret's Page Range Formatter.
          Indiscripts :: Page Range Formatter
          Uwe
          1 person found this helpful
          • 2. Re: Find the same page number in the same paragraph
            mmm... interesting
            I think is good for start. Thanks so much Laubender!
            • 3. Re: Find the same page number in the same paragraph
              Hello!
              I have the solution.
              I share 2 scripts, unfortunate I can not do with InDesign and I used python. I hope is helpful to someone.
              1º SCRIPT - INDEX FIND DUPLICATE NUMBER PAGES
              Download the files
              SCRIPT:
              index.py
              import re
              import sys
              # all possible unicode dashes
              dashes = '\u002D|\u058A|\u05BE|\u1400|\u1806|\u2010|\u2011|\u2012|\u2013|\u2014|\u2015|\u2E17|\u2E1A|\u2E3A|\u2E3B|\u2E40|\u301C|\u3030|\u30A0|\uFE31|\uFE32|\uFE58|\uFE63|\uFF0D'
              def validate_nums(nums):
              seen = []
              for num in nums:
              if num in seen:
              return False
              seen.append(num)
              return True
              def find_errors(filename):
              try:
              with open(filename, 'r') as f:
              i = 1
              for line in f:
              line = re.split('(\d+|{0})'.format(dashes), line)
              nums = []
              dash = False
              for s in line:
              if s.isdigit():
              n = int(s)
              if dash:
              nums.extend(range(nums[-1]+1, n+1))
              dash = False
              else:
              nums.append(n)
              elif re.match(dashes, s):
              dash = True
              if not (validate_nums(nums)):
              print("Error on line ", i)
              i += 1
              except FileNotFoundError as e:
              print("No such file found.")
              def main():
              try:
              find_errors(sys.argv[1])
              except IndexError as e:
              print("You need to specify the filename when calling the script.")
              if __name__ == '__main__':
              main()
              index.txt
              human  27–29, 27,29
              human rights  50, 50-60
              beings  34, 100
              DESCRIPTION:
              This script find the error page numbers in a Index. The script will output the numbers of the wrong lines.
              For example, the next entry have a mistake, because the number 50 already is include in the range of "50-60"
              Human 10, 50, 50-60
              Then the script will output the number error line, after you manually can modify. The correct line will be:
              Human 10, 50-60
              1. install python 3.
              NOTICE: you need run the python version 3, because is not working properly with python 2.
              2. check in terminal if you have the version python 3, with this:
              python3 -V
              The output will be something like this:
              Python 3.7.0
              3. Run the script in terminal:
              python3 index.py index.txt
              Notice, also you can run multiples files, type this in terminal:
              python3 index.py index1.txt index2.txt index3.txt
              4. you will get the number line errors, similar like this:
              Error on line 2
              Error on line 3
              Error on line 5
              Error on line 15
              Error on line 38
              Error on line 159
              Error on line 160
              Error on line 161
              Error on line 162
              Error on line 163
              Error on line 221
              Error on line 239
              5. Enjoy!
              2º SCRIPT - INDEX FIND RANGE OF PAGES GREATHER THAN X NUMBER
              Download the files
              IMAGES:
              SCRIPT:
              index.py
              import re
              import sys
              RANGE_LIMIT = 7 # maximum page range limit, change this to what you want
              try:
              i = 1
              for line in f:
              matches = re.findall('\d+\s*(?:{0})\s*\d+'.format(dashes), line)
              for match in matches:
              match = re.split(dashes, match)
              n1 = int(match[0])
              n2 = int(match[1])
              if n2 - n1 > RANGE_LIMIT:
              print("Excessively large range on line ", i)
              i += 1
              def main():
              fnames = sys.argv[1:]
              if not fnames:
              else:
              for fname in fnames:
              print("Errors in file {0}:".format(fname))
              print()
              main()
              index.txt
              human  27–29, 27,29
              beings  34, 100
              DESCRIPTION:
              This script find the error page numbers in a Index. The script will output the numbers with a range bigger than specify for you in the variable RANGE_LIMIT.
              Example: error output if you have config your RANGE_LIMIT =7, and the script find the next range:
              Human 10, 50-60
              The error is because the range of 50-60 is 10, and you said the RANGE_LIMIT=7
              INSTRUCTIONS:
              python3 -V
              Python 3.7.0
              Error on line 2
              Error on line 3
              Error on line 5
              Error on line 15
              Error on line 38
              Error on line 159
              Error on line 160
              Error on line 161
              Error on line 162
              Error on line 163
              Error on line 221
              Error on line 239
              5. Enjoy!
