Hi there,
Something happened from one day to the other to my Premiere, without me changing any settings: when I apply an effect - like changing the exposure or contrast with Lumetri, or adding Gaussian Blur - I cannot see how that affects the clip simultaneously. The yellow render line appears and I have to render before checking out what the footage looks like with the respective effects. It's really weird and annoying: in case I apply Lumetri, render the footage and it looks graded, if I change any of the Lumetri settings, the footage looks again as the original ungraded file - and I have to render again to show the updated effect applied. Pretty much this makes it virtually impossible to do color grading on Premiere since I have to render to see any change I do.
I know how with the yellow render line playback is not perfect, but you normally can play it somehow ok with new effects applied to it.
Again, this has never been like that before and I haven't changed any of the project settings. I've been working on the same project and from one day to the other this started happening.
I contacted Adobe's customer support, they cleaned my cache files, changed settings here and there, but the problem persists It's really frustrating.
Any advice is welcomed!
Andre
Forgot to turn off the FX button in the Program Window?
Hi
Give us more information, what acceleration Mercury Playback Engine are you using? Have you updated your Premiere Pro lately? What format of video files and codec are your videos? Did you update your Windows? This information is very helpful to be able to discard possibilities and if you can upload screenshots of your entire interface and the effects you are applying would be much better.
Ohh...what a silly mistake - it was just the FX button in the Program Window that was off! I'm glad, however, that it was not something more complicated to fix and I can get it to work now . Thanks for both posts, especially to Ann Bens!
If its any consolation: happened to me too.
It does help
