2 Replies Latest reply on May 30, 2018 1:56 PM by srishtib8795206
    GREP
    sasimaries
      there 500 sets.
      Each set have two lines with hard returns
      i want change it as
      first line with hard return with no after space- Red Character Color
      Second line with hard return with after spce 2mm - Chatacter Color Blue
      please tell me the easiest way to change them
        • 1. Re: GREP
          SJRiegel Adobe Community Professional & MVP
          If all of the text is consistent in the number of lines, you could set up three paragraph styles. Set up each subsequent on as Next Style to the one before, and set the first one as Next Style to the last one.
          Then you can select all of the text, right-click on the first style, and use Apply Style, then Next Style. Your selected styles will cascade through all of the text.
          3 people found this helpful
          • 2. Re: GREP
            srishtib8795206 Adobe Employee
            Hi Sasi,
            I would like to know if the steps suggested by Susan worked for you, or the issue still persists.
            Kindly update the discussion if you need further assistance with it.
            Srishti
