8 Replies Latest reply on May 18, 2018 12:21 PM by Steve Werner
    cc-series  missing  center-node  for  positioning …
    boots_n_patches Level 1
      cc-series  seems  to  be  missing  the  center-node  for  positioning … i  need  that  center-node  for  precise  positioning …
      system: mac-osx-10.12.6 (sierra)
      software: indesign-cs6 ver 8.0
      software: indesign-cc(2018) ver 13.0.0
      line-element:
      width: .5pt
      length: .25”
      view: normal
      moving:  (appears only when moving) … when  moving  the  'line-element'… the  following  behavior  appears:
      indd.cs6:  center  contains  “node”.
      indd.cc2017:  center  does  not  contain  “node”.
      indd.cc2018:  center  does  not  contain  “node”.
      i  am  not  getting  along  well  with  cc-2018 … seems  there  is  no  center-node (line-element) … only  cs6  contains  my  faithful  'center-node'.  i  have  checked  program-prefs  as  well  as  stroke-prefs … i  need  the  center-node  for  precise  ‘positioning’ … any  thoughts?
      attached  two  screen-caps … pls  compare  with  each  other … thanks  in  advance.
