Hello !
I would like to render multiple clips automaticaly and separately keeping the original name.
Example with picture below:
I would like to select the whole project and render each video segment separately keeping the original name.
Thank you in advance !
Well, i discovered a way to do it, you just select the whole project and make a subsequence, after that you go to File> Project Manager > select the sequence and export it as individual clips. My only issue now is that the dimensions of the export is pretty big and i would like to lower the export dimension.
Alas you will have to do this manually for each clip.
There is no such feature but let it known here:
OK, you mean file size?
Yes, exactly !
