Dragable Handle are wrong after export
May 19, 2018 May 19, 2018
When I animate within Adobe Character Animator the draggable handles work fine. But when I export the video via media encoder or link it into after effects as an embedded project file the arms stretch and move randomly. I'm not sure why this is happening.
I did notice that this only happens if the character has to be scaled down. If the character is not scaled it doesn't happen at all.
This is the video export
And that's within the program.
This does not happen within the character animator program beta version at all.
724
Random suggestion - sounds like the puppet is being scaled down, but not the dragging event coordinates. Are there options to scale the puppet vs the whole scene? Maybe you are scaling the wrong ”thing” in AE?  (I don’t know if a feature or bug - I don’t use AE - just trying a random suggestion. I notice that draggers are not relative to the rest of the puppet, so the same happens inside CH as well. Just wondering if you scan scale the whole scene instead, which would include the draggers at a guess.)
Great suggestions. When you scale the scene the whole scene disappears. This is definitely a bug in character animator 2018.
I just tried scaling down the puppet and it's doing the same thing as well.
Guru ,
Can you post a screen cap of your rigging panel? I've tried a number of different riggings and finally came up with this result. Is it something like you are seeing?
Yeah that looks pretty much like whats happening for me too
Guru ,
I cannot reproduce it with the arms being independent. Here is my rigging, showing the mesh that goes with it. You might take a look at your mesh.
Ok, that might be the issue. Let me see if there is a layer with extra drawings.
And this is the file that is having the same issue. And the arms don't have a mesh which is weird.
The rectangular mesh means its not using the correct mesh - warping will look weird. There is normally something “disconnected” in the layers. An easy quick fix is to set the “mesh type” property to “contour” to speed it up.
The second image showing the arms without mesh is because the arms are independent. When you click on an arm group, you will see the mesh for that arm.
Oh, in that first picture with the rectangular mesh, what is that anchor or handle right up in the top left corner? I wonder if that floating off on its own is cause the mesh calculation to go weird.
On, your first puppet had some other things that were hidden. You need to delete, not just hide. Hidden things are still used in the mesh calculations since you may use triggers to make them appear. So the “don’t use these naughty...” and “BG” groups I would delete (not just hide).
May 20, 2018 May 20, 2018
I fixed the mesh issue and moved the handle. Also deleted the extra layers and still it's happening during export. But when I export the demo puppets it works just fine. So I wonder if it's a photoshop puppet issue maybe.
