I have two webservices which I am trying to consume one after
the other. The first webservice does return a true string, but the
second webservice displays an error as it is unable to find the
session variable that I setup in the first webservice.
What should I do? How should I call the session variable when
I invoke the webservice?
first Webservice in a file:
<cffunction name="setUpWebUserSession" access="remote"
output="false" returntype="string"
displayname="setUpWebUserSession">
<cfset isSuccesful="true">
<cfargument name="userName" required="true"
default="">
<cfargument name="applicationToLogIn" required="true"
default="">
<cflock scope="session" throwontimeout="true"
timeout="120" type="exclusive"><!--- --->
<cfset session.WebUserUI = createObject("component",
"org.atcc.webuser.client.presentation.WebUserUI")>
</cflock>
<cfreturn isSuccesful>
Second webservice in the same file:-
<cffunction name="getProfileHTML" access="remote"
displayname="getProfileHTML" output="false" returntype="string">
<cfset var profileHTML = "">
<cfsavecontent variable="profileHTML">
<cfoutput>#session.WebUserUI.getWebProfileHTML()#</cfoutput>
</cfsavecontent>
<cfreturn
application.CTiStringCleaner.getCleanString(profileHTML)>
<!--- <cfreturn profileHTML> --->
</cffunction>
Error Message from Axis:
ErrorCode:
message: session.WebUserUI.getSalesOrderHistorySection()
doesn't exist.
detail: Error at line 1, column 52
the way I am consuming webservice
<cfcomponent>
<cfinvoke webservice="
http://172.0.0.1:8080//WebServicesAPI.cfc?wsdl"
method="setUpWebUserSession"
returnVariable="soo">
<cfinvokeargument name="userName"
value="muddu_shafi@yahoo.com">
<cfinvokeargument name="applicationToLogIn"
value="atccWeb">
</cfinvoke>
<cfoutput> #soo# </cfoutput>
method= "getSaleOrderHistoryHTML"
returnVariable="foo">
</cfinvoke>
<cfoutput>#foo#</cfoutput>
<!-- TS024546-->
</cfcomponent>
First Web service
Second webservice
