Can someone help me with this?
All text fields merge into my InDesign file, though all pone numbers and e-mail addresses don't merge.
You have to set them up as text in MS Excel. I do it always with a duplicated sheet and set all values as text.
Here are some things to try if data merge is not working:
- if using comma delimited, try using tab delimited and vice versa
- check data for inconsistencies, like soft returns, special characters, commas, etc.
- save source data with UTF-8 encoding
- try different application for saving .csv or .txt source data
- check if header row is complete
We would need to see more information before being able to accurately troubleshoot this issue, but I suspect that Jeffrey_Smith has the right answer in the last bullet point of his post - check if the header row is complete.
The header row is what Data Merge uses to create the field headings. If the field headings abruptly stop but there's actually data in the subsequent rows, Data Merge won't care and will only show the fields that had a header row. There's more information in this post that I hope helps in this situation: https://indesignsecrets.com/troubleshooting-data-merge-errors.php
Hi there,
I would like to know if the steps suggested above worked for you, or the issue still persists.
Kindly update the discussion if you need further assistance with it.
Srishti
