Help. I have some elements showing up as 'Tagged content - Failed' in PDF Accessibility Checker. When I right-click to 'Show in Content Panel' I receive a message 'The selection was not found in the Content Panel'. The elements appear to be the tabbed spaces between a bullet point and text within a table. How do I fix this to make my document accessible?
In case you haven't yet found the answer to this question..
In the description of the error, it might be because there is untagged content in the PDF. Even invisible tabs and spaces must be tagged, either with a regular text tag or as an artifact.
Two possible solutions (hopefully you have the latest DC:2018 version of Acrobat Pro which has better tools to do this):
If you are confident that the 'untagged content' is not actually carrying any meaningful or relevant content, you may also use Acrobat Preflight and run the fixup "Mark all non-structure elements as artifact" - it will wrap any content that does not yet belong to the tag tree in an Artifact marked content sequence. BUT please make sure you are not artifacting / excluding from the tag tree any content that IS relevant.
