After the last program update, the magnetic lasso stopped working and the program closes with an error
Hi All,
Please update Photoshop to 19.1.1 version, which includes the fix for "Photoshop CC 2018 crashes while using Pen/Magnetic Lasso Tool".
Also, refer the list of other fixed issues in 19.1.1 release: https://helpx.adobe.com/photoshop/kb/fixed-issues.html
To update Photoshop CC to 19.1.1, click "Update" in the Creative Cloud desktop app next to Photoshop CC.
Mohit
What have you done for trouble-shooting so far?
Restoring Preferences after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved might be a good starting point:
https://helpx.adobe.com/photoshop/kb/basic-trouble-shooting-steps.html
Recently, i have faced same problem.. Any Solution?
Have you reset the Tool yet?
I tried to use that reset tool within Photoshop before as well and had a similar problem. I think i should install Photoshop again. Is it Right?
After resetting the settings, the lasso worked. Now I find out that after the update was not compatible with the previous version
settings dropped just renaming the folder with: \ Users \ ******** \ AppData \ Roaming \ Adobe \ Adobe Photoshop CC 2018 farther on the file threw everything back until I found what was the cause
PS 2018 rel 19.1.0, Win10, video ATI
Outstanding. Resolve the Problem.
Thanks a Lot!
An error was found. The problem is in the cursor settings. If you change the cursor settings to "Precies", then when you use the lasso the program crashes. The problem is only with a magnetic lasso. A temporary solution is to not use this cursor mode.
And this only applies to "Other Cursors". There are no problems with brushes.
In those support appealed, they looked at this problem, and defined it as an error in the program. Promised in the following releases or patch fix
Hi there,
Sorry about the inconvenience caused. We are investigating this issue and will update this discussion with our findings.
Akash
Any updates?
I am having the same issue after updating to CC 2018 yesterday. Pressing "L" for the polygonal lasso tool causes an immediate crash with no error report or notification from Photoshop. I have reset the all lasso tools and restarted. Other cursors is already set to standard (has never been "precise.")
With today's update (Photoshop 19.1.1) the problem is solved... at least for me
Today’s update (19.1.1) fixes this crash. Downloaded, tested and confirmed.
Hi All,
Mohit
I updated (actually went back to) the Version 19.1.1 release, and am still having the same issues: Magnetic Lasso completely crashes the entire system. What happens is that when you click on the lasso, you cannot turn it off. It continues to lasso along with the cursor and the only way to stop it is to close out of PS (which is not easy either, as the cursor will not release from the lasso). I am now updating to the most recent version release, but that was installed when I needed to join the forum in the first place. Bottom line: It has NOT "been fixed."
Hi roberts,
We're really sorry for all the hassle caused you. You may try resetting the Photoshop 19.1.4 preferences back to defaults and check if that helps to fix this issue, refer: Preferences in Photoshop
Mohit
