Ben, Thanks for the response. I always start a list using the
toolbar button, whether ordered or unordered. Though occasionally
the "Format | Bullets and Numbering" menu options come into play if
I need to change the bullet or number style for some reason. And
occasionally, from that approach the Numbered examples on the
Bullet & Numbering dialog will end up with two or three similar
list examples on the same display (multiple 1,2,3 etc), and I'm
never sure what the differences are. I'm thinking perhaps I've
somehow used different styles without being aware I have.
The following is an example of code that's working the way I
expect. The only difference I see between this below, and the code
that is not working the way I want is the "list style: inside
decimal" tag.
<p style="margin-left: 0px;"> </p>
<ol style="list-style: decimal;" type=1>
<li class=p><p style="margin-left: 0px;">On the
<span style="font-weight: bold;">Borrower
Services</span> tab, with the borrower's account
displayed, click <span
style="font-weight: bold;">Requests</span>.
<spaces> </spaces>The
<span style="font-weight: bold;">Place
Requests</span> sub-tab will open
as shown in the example above. </p></li>
<li class=p><p style="margin-left: 0px; margin-top:
4.5pt;">Type or
scan the <span style="font-weight: bold;">Item
ID</span> in the <span
style="font-weight: bold;">Title Search</span> box
and click <span style="font-weight:
bold;">Search</span>.
<spaces> </spaces>Or you can search for
the title by typing a search
term in the <span style="font-weight: bold;">Title
Search</span> box and
clicking <span style="font-weight:
<spaces> </spaces>See
<a href="Do_a_Title_Search.htm">Search for a
Title</a> to learn more about
how to search for a title.</p></li>
4.5pt;">From the
search results locate and select the title of the item you
want to request.
<spaces> </spaces>The <span
style="font-weight: bold;">Title</span>
field will now display the title, as shown in the example
above. </p></li>
4.5pt;">Under <span
style="font-weight: bold;">Request Type</span> the
options will now be
available, and the <span style="font-weight:
bold;">First Available</span>
option will be selected by default.
<spaces> </spaces>Retain that
selection, or select another option as
appropriate.</p></li>
4.5pt;">Each option
is listed below, along with the steps to place a Request
using the option.
Joe
