Hello! Maybe a simple answer...
Can premiere pro sort Photoshop file according to layers in file?
For example, when I look at the list of layers that make up my psd, why are they in different order than what they are in the psd file. AND when I drag all layers to time line, is there a way to stack on top of each other? Instead of end to end?
Thank you!!!
Import the psd as a sequence.
I will try that. IT WORKED! GENIUS... you will save me so much time in the future!!! Thank you! Sleep well, knowing you care to make a difference! Love it!!!!
If you want to stack multiple clips you make a multicam source squence in the project window. (select clips > right click)
