how to decrease speed of multiple image clips?
May 27, 2018 May 27, 2018
1st problem: i have multiple image that i want to combine into a video, but when i check box the image sequence and import them, some of the image were stacking or scale really small for unknown reason, like this bandicam 2018-05-27 21-07-15-766.jpg - Google Drive . is it due to the picture were not in the same aspect ratio as the sequence were set to?
2nd problem: because of the problem i stated above, i couldn't do the work simple, so i have to put each image into the sequence and set the duration manually, now i want to decrease the duration of all the clips in the sequence, but i cant which i guess due to all the clips were right next to each other sticking, can anyone help me with this issue? if someone know how to fix the first problem then i guess no need to answer this second problem
any answer is appreciated:)
228
Community Expert , May 27, 2018 May 27, 2018
Select the ripple edit tool and select the clips, the drag left (or right if you want to extend them)
This is one way of doing this but the feature for now is broken have to wait for an update.
If all your images have the same duration you can select them on the timeline.
Right click > Speed/Duration and adjust.
thank you so much, that really helps me a lot. too bad that feature is broken:/
