I just tried to open PDF files and I cant get one to open, or any of the old ones I have stored on my computer. I have MacOS Sierra 10.12. I don't know what happned but I tried to reinstall Acrobat and when it got to a certain point it told me that there was a higher version found and the instaillation would terminate. So I am stuck Please HELP.
Your description is not very clear. Do you have Adobe Acrobat or Adobe Reader installed, or not? If so, what version?
I have adobe acrobat I am not sure what version. I don't know how to check that. All I know is that I cannot open any PDF file.
It is adobe acrobat reader
This is an error message I received when trying to open a document..
Process: AdobeReader [1418]
Path: /Applications/Adobe Acrobat Reader DC.app/Contents/MacOS/AdobeReader
Identifier: com.adobe.Reader
Version: 18.011.20038 (18.011.20038)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: AdobeReader [1418]
User ID: 501
Date/Time: 2018-04-08 10:25:07.671 -0500
OS Version: Mac OS X 10.12.6 (16G1314)
Report Version: 12
Anonymous UUID: C61D21B9-A1A3-3D5C-8A51-2407C67EAE1B
Sleep/Wake UUID: 79F0E223-D3AE-456E-A1A2-EE1CC0456199
Time Awake Since Boot: 10000 seconds
Time Since Wake: 190 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x5] Code Signature
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @loader_path/../AdobeACE.framework/Versions/A/AdobeACE
Referenced from: /Applications/Adobe Acrobat Reader DC.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
Reason: no suitable image found. Did find:
/Applications/Adobe Acrobat Reader DC.app/Contents/MacOS/../Frameworks/Acrobat.framework/../AdobeACE.framework/Versions/A/AdobeACE: code signature invalid for '/Applications/Adobe Acrobat Reader DC.app/Contents/MacOS/../Frameworks/Acrobat.framework/../AdobeACE.framework/Versions/A/AdobeACE'
Binary Images:
0x101079000 - 0x101079fff +com.adobe.Reader (18.011.20038 - 18.011.20038) <9F69398A-30AA-3B49-BFA8-6235F6B94737> /Applications/Adobe Acrobat Reader DC.app/Contents/MacOS/AdobeReader
0x10107f000 - 0x102d26fff +com.adobe.Acrobat.framework (18.011.20038 - 18.011.20038) <A7581E90-DCAD-31E9-A6CB-EB716F3701D1> /Applications/Adobe Acrobat Reader DC.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
0x10a8e2000 - 0x10a91fdc7 dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
0x7fffa2adb000 - 0x7fffa38b4ff3 com.apple.AppKit (6.9 - 1504.83.101) <59B096DA-5F32-3987-921A-D32210A52839> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fffa6a1b000 - 0x7fffa6dc1fff com.apple.Foundation (6.9 - 1349.91) <2A521CFB-7F0F-3226-9DAE-73CEDB6EF4ED> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fffb920c000 - 0x7fffb920dffb libSystem.B.dylib (1238.60.2) <F3BF9DA9-7FF1-3B43-A33F-3481DF9C8A82> /usr/lib/libSystem.B.dylib
0x7fffb9eba000 - 0x7fffba28c047 libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
0x7fffba4f8000 - 0x7fffba548fff libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
0x7fffba6b9000 - 0x7fffba6caff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
Model: MacBookAir7,2, BootROM MBA71.0176.B00, 2 processors, Intel Core i7, 2.2 GHz, 8 GB, SMC 2.27f2
Graphics: Intel HD Graphics 6000, Intel HD Graphics 6000, Built-In
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80CE, 0x4B3445364533303445452D45474345000000
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80CE, 0x4B3445364533303445452D45474345000000
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x117), Broadcom BCM43xx 1.0 (7.21.171.133.1a2)
Bluetooth: Version 5.0.5f1, 3 services, 17 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM0128G, 121.33 GB
USB Device: USB 3.0 Bus
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Air, Apple Inc., 27.2
Is there anyone that can help with my situation?
Hello Karenr,
Sorry for the delayed response and inconvenience caused. Please check for any pending updates of Adobe Reader from help>check for updates, reboot the machine after installing the updates and see if this brings any difference.
If the issue persists, please use Acrobat cleaner tool to remove Adobe Reader Download Adobe Reader and Acrobat Cleaner Tool - Adobe Labs
Reboot the machine and install latest Adobe Reader from Adobe - Adobe Acrobat Reader DC Distribution
You can also refer and try the suggestions from the following Adobe URL Can't open PDF
Let us know how it goes and share your findings.
Anand Sri.
