I'm not native English.
I have a file with a lot of linked Smart Objects.
The folder for these objects has now been moved. Photoshop no longer finds the files automatically.
This is about the setup of my PSD file:
PSD file with 400 linked Smart Objects.
These were previously on the hard disk like this:
C://Pojekt33/Footage/Angle000/beauty.exr
C://Pojekt33/Footage/Angle001/beauty.exr
C://Pojekt33/Footage/Angle002/beauty.exr
C://Pojekt33/Footage/Angle399/beauty.exr
The new path is now as follows:
C://Pojekt33/Final/Example/Footage/Angle000/beauty.exr
C://Pojekt33/Final/Example/Footage/Angle001/beauty.exr
C://Pojekt33/Final/Example/Footage/Angle002/beauty.exr
C://Pojekt33/Final/Example/Footage/Angle399/beauty.exr
Photoshop is not able to automatically re-link all Smart Objects. Probably because all files have the same name.
Is there a way to have only the part of the file path changed automatically?
Via Java Script e.g.?
If I look at the PSD file with a HEX editor, I can see the paths clearly (in the XMP).
Here is an excerpt of this file:
<xmpMM:Ingredients>
<rdf:Bag>
<rdf:li rdf:parseType="Resource">
<stRef:linkForm>ReferenceStream</stRef:linkForm>
<stRef:filePath>file:///C://Pojekt33/Footage/Angle000/beauty.exr</stRef:filePath>
</rdf:li>
<stRef:filePath>file:///C://Pojekt33/Footage/Angle001/beauty.exr</stRef:filePath>
</rdf:li>
<stRef:filePath>file:///C://Pojekt33/Footage/Angle002/beauty.exr</stRef:filePath>
</rdf:li>
Now I could simply exchange all paths in a hex editor via "Search and Replace". But when I save the edited PSD, Photoshop doesn't open it anymore. An error then appears. The window will show "EOF - End Of File".
The only possibility now is to reconnect all linked content by hand. This is very complex and takes a long time. Is there another option here?
Thank you very much for your help!
Hi
I'll move you post to this forum Photoshop Scripting
I think you might be out of luck as Photoshop uses the file information embeded in the smart object not the metadata
So using a hex editor or changing the metadata will not work.
Example of metadata in smartobject..
"smartObject": { | |
"placed": "rasterizeContent", | |
"documentID": "3C206B39F415165B248A8FDE3CABB8DE", | |
"compsList": { | |
"compID": -1, | |
"originalCompID": -1 | |
"linked": true, | |
"fileReference": "Blue_new.jpg", | |
"link": "/d/a/Blue_new.jpg", | |
"linkMissing": true, | |
"linkChanged": false | |
I almost thought so
That's very annoying. It could be that simple. It is not even necessary to change the complete file path, but only a part of it.
