Optimizing a PDF
May 30, 2018 May 30, 2018
Using: Adobe Acrobat Pro XI
What is the difference between:
Save As Other -> Reduced Size PDF
   and...
Save As Other -> Optimized PDF
General troubleshooting
480
Adobe Employee , May 30, 2018 May 30, 2018
Hi Freds,
The Reduce File Size command resamples and recompresses images, removes embedded Base-14 fonts, and subset-embeds fonts that were left embedded. It also compresses document structure and cleans up elements such as invalid bookmarks. If the file size is already as small as possible, this command has no effect.
Whereas Optimized PDF provides many settings for reducing the size of PDF files. Some of the PDF Optimizer settings are comparable to the settings that are available when you creat
Adobe Employee ,
Hi Freds,
Whereas Optimized PDF provides many settings for reducing the size of PDF files. Some of the PDF Optimizer settings are comparable to the settings that are available when you create a PDF file using Distiller. Whether you use all of these settings or only a few depends on how you intend to use the files and on the essential properties a file must have. In most cases, the default settings are appropriate for maximum efficiency—saving space by removing embedded fonts, compressing images, and removing items from the file that are no longer needed.
Let us know if you have any further query.
Shivam
Thank you for your very comprehensive answer!
There is one other important difference: "Reduced Size PDF" is available in both Acrobat Pro and Standard, whereas "Optimized PDF" is only available in Pro. When you are using "Optimized", you can also use the "Audit space usage" feature to find out which elements in your PDF file are using up what amount of space. This helps to fine-tune your optimization settings.
Mar 24, 2020 Mar 24, 2020
Hi, since i have readible or OCR'd files does optimize remove those keywords, searcable words from the document?
