there 500 sets.
Each set have two lines with hard returns
i want change it as
first line with hard return with no after space- Red Character Color
Second line with hard return with after spce 2mm - Chatacter Color Blue
please tell me the easiest way to change them
If all of the text is consistent in the number of lines, you could set up three paragraph styles. Set up each subsequent on as Next Style to the one before, and set the first one as Next Style to the last one.
Then you can select all of the text, right-click on the first style, and use Apply Style, then Next Style. Your selected styles will cascade through all of the text.
Hi Sasi,
I would like to know if the steps suggested by Susan worked for you, or the issue still persists.
Kindly update the discussion if you need further assistance with it.
Srishti
