Hello all,
I have a PDF that has multiple attachments within it. Is there anyway to print all of these attachments without having to open each one individually and printing from there?
Hi AshlyP,
Sorry for the delayed response.
As per the issue description mentioned above, you want to print all of the attachments in a pdf file without opening each one individually, is that correct?
The functionality of printing multiple pdf attachments in a pdf file is not available. You may also refer to the following forum thread discussing the similar topic: Print pdf and attachments
Let us know if you have a further query.
Shivam
What program are you trying to print from?
Adobe Acrobat Pro DC
Moved to acrobat general troubleshooting.
Hi AshlyP,
Shivam
The forum thread: Print pdf and attachments is broken. Has there been any movement on this issue in the past 5 years? I have a need to convert all attachments of a PDF into PDF and then append them to the same document.
Hello,
I am coming across this issue as well, and would like to know if a solution has been developed.
Same.
