I'm trying to access the guide line positions in my document (ctr-r to bring up the ruler, and drag the line out to the spot you want), and wondering how to access the position of them through code (and if I can directly get the intersection in the document in local positions related to a x y coord in the document)
Example of what I mean:
See if reading this script helps any.
// 2014 John J. McAssey (JJMack)
// This script is supplied as is. It is provided as freeware.
// The author accepts no liability for any problems arising from its use.
/* Help Category note tag menu can be used to place script in automate menu
<javascriptresource>
<about>$$$/JavaScripts/FitImageToGuides/About=JJMack's FitImageToGuides .^r^rCopyright 2014 Mouseprints.^r^rFour and only four guides are required</about>
<category>JJMack's Script</category>
</javascriptresource>
// enable double-clicking from Mac Finder or Windows Explorer
#target photoshop // this command only works in Photoshop CS2 and higher
// bring application forward for double-click events
app.bringToFront();
// ensure at least one document open
if (!documents.length) alert('There are no documents open.', 'No Document');
else {
// declare Global variables
//main(); // at least one document exists proceed
app.activeDocument.suspendHistory('Fix Image to Guides','main()'); //problem if there is a selection a layer resize Photoshop back up a history step ?
// main function
function main() {
// declare local variables
var orig_ruler_units = app.preferences.rulerUnits;
var orig_type_units = app.preferences.typeUnits;
var orig_display_dialogs = app.displayDialogs;
app.preferences.rulerUnits = Units.PIXELS; // Set the ruler units to PIXELS
app.preferences.typeUnits = TypeUnits.POINTS; // Set Type units to POINTS
app.displayDialogs = DialogModes.NO; // Set Dialogs off
try { code(); }
// display error message if something goes wrong
catch(e) { alert(e + ': on line ' + e.line, 'Script Error', true); }
app.displayDialogs = orig_display_dialogs; // Reset display dialogs
app.preferences.typeUnits = orig_type_units; // Reset ruler units to original settings
app.preferences.rulerUnits = orig_ruler_units; // Reset units to original settings
// main function end
// The real code is embedded into this function so that at any point it can return
// to the main line function to let it restore users edit environment and end
function code() {
if (app.activeDocument.guides.length != 4) { alert("Four and only four Guides are required"); return; } // quit
// get guides;
var theVert = new Array;
var theHor = new Array;
for (var m = 0; m < app.activeDocument.guides.length; m++) {
.direction == Direction.HORIZONTAL) {theVert.push(app.activeDocument.guides .coordinate)} else {theHor.push(app.activeDocument.guides
.coordinate)} };
if (theHor.length != 2 || theVert.length != 2) { alert("Four Guides two vertical and two horizontal are required"); return; } // quit
getTarget=getSelectedLayersIdx();
if (getTarget.length!=1){ alert("The number of layers targeted is " + getTarget.length ); return; } // quit
if (app.activeDocument.activeLayer.isBackgroundLayer ) { alert("Can not resize the background layer"); return; } // quit
if (!app.activeDocument.activeLayer.visible ) { alert("Active layer is not visible"); return; } // quit
//if (hasLayerMask()) { alert("Active layer is Masked"); return; } // quit
if (app.activeDocument.activeLayer.kind == LayerKind.NORMAL || app.activeDocument.activeLayer.kind == LayerKind.SMARTOBJECT && hasLayerMask()) { deleteLayerMask ();}
if (app.activeDocument.activeLayer.kind != LayerKind.NORMAL && app.activeDocument.activeLayer.kind != LayerKind.SMARTOBJECT ) {
alert("Active layer is " + app.activeDocument.activeLayer.kind); return; } // quit
// set selection to the area defined but the guide lines the selection may get undone by the bug in .resize() backing up a step in histoty ???
app.activeDocument.selection.select([[theHor[0], theVert[0]], [theHor[1], theVert[0]], [theHor[1], theVert[1]], [theHor[0], theVert[1]]]);
// resize current normal layer or smart object layer to just cover selection canvas area aspect ratio and size and mask off any overflow
var SB = app.activeDocument.selection.bounds; // Get selection bounds
var SWidth = (SB[2].value) - (SB[0].value); // Area width
var SHeight = (SB[3].value) - (SB[1].value); // Area height
var LB = app.activeDocument.activeLayer.bounds; // Get Active layers bounds
var LWidth = (LB[2].value) - (LB[0].value); // Area width
var LHeight = (LB[3].value) - (LB[1].value); // Area height
var userResampleMethod = app.preferences.interpolation; // Save interpolation settings
app.preferences.interpolation = ResampleMethod.BICUBIC; // resample interpolation bicubic
app.activeDocument.selection.deselect(); // This deselect work around Adobe Bug in CS5, CS6, CC and CC 2014
// Since Adobe does not fix old releases of Photoshop this is a necessary work around for many releases of Photoshop
//alert("Before re-size history"); // Added to debug Adobe Resize Bug
try {
if (LWidth/LHeight<SWidth/SHeight) { // layer's Aspect Ratio less the Canvas area Aspect Ratio
var percentageChange = ((SWidth/LWidth)*100); // Resize to canvas area width
app.activeDocument.activeLayer.resize(percentageChange,percentageChange,AnchorPosition.MIDDLECENTER);
else {
var percentageChange = ((SHeight/LHeight)*100); // resize to canvas area height
catch(e) {
app.preferences.interpolation = userResampleMethod; // Reset interpolation setting
selectFront(); // Photoshop make top layer current when none are targeted
code(); // Retry with top visible layer selected targeted
return; // rest would have been done during the retry
//alert("After re-size history"); // Added to debug Adobe Resize Bug
// Seems to be a bug in resize() the document seems to first be backed up a step in history
app.activeDocument.selection.select([[theHor[0], theVert[0]], [theHor[1], theVert[0]], [theHor[1], theVert[1]], [theHor[0], theVert[1]]]); // redo the selection
align('AdCH'); // align to horizontal centers
align('AdCV'); // align to vertical centers
addLayermask(); // add layer mask to mask off excess
// Helper Functions
function align(method) {
var desc = new ActionDescriptor();
var ref = new ActionReference();
ref.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
desc.putReference( charIDToTypeID( "null" ), ref );
desc.putEnumerated( charIDToTypeID( "Usng" ), charIDToTypeID( "ADSt" ), charIDToTypeID( method ) );
try{executeAction( charIDToTypeID( "Algn" ), desc, DialogModes.NO );}
catch(e){}
// Function: hasLayerMask
// Usage: see if there is a raster layer mask
// Input: <none> Must have an open document
// Return: true if there is a vector mask
function hasLayerMask() {
var hasLayerMask = false;
try {
var keyUserMaskEnabled = app.charIDToTypeID( 'UsrM' );
ref.putProperty( app.charIDToTypeID( 'Prpr' ), keyUserMaskEnabled );
ref.putEnumerated( app.charIDToTypeID( 'Lyr ' ), app.charIDToTypeID( 'Ordn' ), app.charIDToTypeID( 'Trgt' ) );
var desc = executeActionGet( ref );
if ( desc.hasKey( keyUserMaskEnabled ) ) { hasLayerMask = true; }
catch(e) { hasLayerMask = false; }
return hasLayerMask;
function getSelectedLayersIdx(){
var selectedLayers = new Array;
ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
var desc = executeActionGet(ref);
if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
var c = desc.count
var selectedLayers = new Array();
for(var i=0;i<c;i++){
try{
activeDocument.backgroundLayer;
selectedLayers.push( desc.getReference( i ).getIndex() );
}catch(e){
selectedLayers.push( desc.getReference( i ).getIndex()+1 );
}else{
ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
try{
selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1);
}catch(e){
selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" )));
return selectedLayers;
function selectFront() {
// Alt+. shortcut select ftont visible layer
var idslct = charIDToTypeID( "slct" );
var desc250 = new ActionDescriptor();
var idnull = charIDToTypeID( "null" );
var ref207 = new ActionReference();
var idLyr = charIDToTypeID( "Lyr " );
var idOrdn = charIDToTypeID( "Ordn" );
var idFrnt = charIDToTypeID( "Frnt" );
ref207.putEnumerated( idLyr, idOrdn, idFrnt );
desc250.putReference( idnull, ref207 );
var idMkVs = charIDToTypeID( "MkVs" );
desc250.putBoolean( idMkVs, false );
executeAction( idslct, desc250, DialogModes.NO );
function deleteLayerMask (apply) {
// Delet Layer mask default to not apply first
if (apply == undefined) {var apply = false};
try {
var idDlt = charIDToTypeID( "Dlt " );
var desc9 = new ActionDescriptor();
var ref5 = new ActionReference();
var idChnl = charIDToTypeID( "Chnl" );
var idMsk = charIDToTypeID( "Msk " );
ref5.putEnumerated( idChnl, idChnl, idMsk );
desc9.putReference( idnull, ref5 );
var idAply = charIDToTypeID( "Aply" );
desc9.putBoolean( idAply, apply );
executeAction( idDlt, desc9, DialogModes.NO );
catch (e) {}
function addLayermask(){
// Add layer Mask
var idMk = charIDToTypeID( "Mk " );
var desc52 = new ActionDescriptor();
var idNw = charIDToTypeID( "Nw " );
desc52.putClass( idNw, idChnl );
var idAt = charIDToTypeID( "At " );
var ref19 = new ActionReference();
ref19.putEnumerated( idChnl, idChnl, idMsk );
desc52.putReference( idAt, ref19 );
var idUsng = charIDToTypeID( "Usng" );
var idUsrM = charIDToTypeID( "UsrM" );
var idRvlS = charIDToTypeID( "RvlS" );
desc52.putEnumerated( idUsng, idUsrM, idRvlS );
executeAction( idMk, desc52, DialogModes.NO );
// Un link layer mask just added fron the layers content
var idsetd = charIDToTypeID( "setd" );
var desc2 = new ActionDescriptor();
var ref1 = new ActionReference();
var idTrgt = charIDToTypeID( "Trgt" );
ref1.putEnumerated( idLyr, idOrdn, idTrgt );
desc2.putReference( idnull, ref1 );
var idT = charIDToTypeID( "T " );
var desc3 = new ActionDescriptor();
var idUsrs = charIDToTypeID( "Usrs" );
desc3.putBoolean( idUsrs, false );
desc2.putObject( idT, idLyr, desc3 );
executeAction( idsetd, desc2, DialogModes.NO );
I can only find a way by using DOM.
//Requires Photoshop CS5 or newer
#target photoshop;
var guides = app.activeDocument.guides;
var X,Y;
if(guides.length == 2){
if(guides[0].direction == "Direction.VERTICAL"){
X = guides[0].coordinate.value;
}else{
Y = guides[0].coordinate.value;
if(guides[1].direction == "Direction.VERTICAL"){
X = guides[1].coordinate.value;
}else{
Y = guides[1].coordinate.value;
alert("X = " + X.toFixed(0) + " Y = " + Y.toFixed(0));
Guides are an array so if it's the first guide you placed "i" should be 0. If it's the 2nd you placed. "i" should be 1.
A guide has 2 variables you can get.
app.activeDocument.guides.direction
app.activeDocument.guides.coordinate
the direction outputs "direction.VERTICAL" or "direction.HORIZONTAL".
The coordinate is the X or Y position, depending on what the direction is.
the intersecting position you seek is basicly just the 2 coordinates together.
//If the vertical guide is the 1st placed guide
var intersectingPositionX = app.activeDocument.guides[0].coordinate
var intersectingPositionY app.activeDocument.guides[1].coordinate
//Otherwise its this
//var intersectingPositionY = app.activeDocument.guides[0].coordinate
//var intersectingPositionX app.activeDocument.guides[1].coordinate
As an alternative to using guides you could use the ruler offset. Just drag the ruler offset to where you want.
You can then get the results and reset the offset.
Example:-
alert(getRulerOffset());
SetRulerOrigin(0,0);
function getRulerOffset(){
var r = new ActionReference();
r.putEnumerated(stringIDToTypeID("document"), stringIDToTypeID("ordinal"), stringIDToTypeID("targetEnum"));
var desc = executeActionGet(r);
var h= desc.getInteger(stringIDToTypeID("rulerOriginH"))>> 16;
var v= desc.getInteger(stringIDToTypeID("rulerOriginH"))>> 16;
return [h,v];
function SetRulerOrigin(horiz, vert) {
ref.putProperty(app.stringIDToTypeID("property"), app.stringIDToTypeID("rulerOriginH"));
ref.putEnumerated(app.stringIDToTypeID("document"), app.stringIDToTypeID("ordinal"), app.stringIDToTypeID("targetEnum"));
desc.putReference(app.stringIDToTypeID("null"), ref);
desc.putInteger(app.stringIDToTypeID("to"), horiz << 16);
executeAction(app.stringIDToTypeID("set"), desc, DialogModes.NO);
ref.putProperty(app.stringIDToTypeID("property"),app.stringIDToTypeID("rulerOriginV"));
desc.putInteger(app.stringIDToTypeID("to"), vert << 16);
