sel.duplicate problem
Jun 03, 2018 Jun 03, 2018
I'm trying to copy blocks of text from one file to a series of new files - each block in it's own file,
The following code works -- USUALLY. occasionally the text in the new file is truncated in the middle (with no pattern as to when it is truncated.
the alert shows the complete text block so I know the sel is correct
any ideas as to what could be causing the problem?
thanks
app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
    app.findGrepPreferences.findWhat=" newblock";
    found=app.activeDocument.findGrep();
    for(i=0;i<found.length-1;i++){
        ipStart=found.index;
        ipEnd=found[i+1].index-1;
        sel = found[0].parentStory.characters.itemByRange(ipStart,ipEnd);
       //alert(i+"\r"+sel.contents);
        nd=makeNewDoc();// creates new doc - sets margins
        ntf=nd.pages[0].textFrames.add();
        gb=ntf.geometricBounds;
        gb[2]=gb[3]=200;
        gb[0]=gb[1]=0;
        ntf.geometricBounds=gb;
       sel.duplicate(LocationOptions.AT_BEGINNING,ntf);
Scripting
581
Advocate , Jun 04, 2018 Jun 04, 2018
As per your need I can understand, I think you should try this
app.findGrepPreferences.findWhat="newblock";
var ipStart = null;
var ipEnd = null;
for(i=0; i < found.length; i++){
    if(i==0){
        ipStart = found.characters[0].index;
    else{
        if(i < found.length-1){
            ipEnd=found.characters[0].index-1;
        else if(i < found.length){
Advocate ,
Hi there,
          If you are more concerned about text only, then instead of grep you should try text search, so your code should be like this,
app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
app.findTextPreferences.findWhat=" newblock";
found=app.activeDocument.findText();
    nd=makeNewDoc();
    gb[2]=gb[3]=200;
    gb[0]=gb[1]=0;
Hi
I need to use grep -- "new block" is preceded by numbers that have to be included. I left that out because it doesn't affect the script example
Follow up experimenting: if I make the textFrame huge (so the entire text block fits into the frame) then it seems to work properly...
Which doesn't make any sense (as far as I can see)
Any ideas why?
thanks
Advocate ,
var ipStart = null;
var ipEnd = null;
    if(i==0){
    else{
            //******you can choose here if you want to add character after last newblock to the end of your story or not******//
            ipEnd=found.parent.characters[found.parent.characters.length-1];
        var nd = app.documents.add();
        gb[2]=gb[3]=200;
        gb[0]=gb[1]=0;
Guide ,
What if you duplicate the text into ntf.parentStory (instead of ntf)?
Marc
