The function below prints the time using the 24hr clock format. When the hours, minutes and seconds are less than 10, the time value is printed in a single digit format. Can someone give me an idea of how to format the time so that it always prints in a double digit format.
For instance the time 21:0:5 would be 21:00:05
alert(runTime())
function runTime () {
try{
var digital = new Date();
var hours = digital.getHours();
var minutes = digital.getMinutes();
var seconds = digital.getSeconds();
var milliseconds = digital.getMilliseconds();
militaryTime = hours + ":" + minutes + ":" + seconds;
return militaryTime;
} catch(e) {alert(e)}
var theNumber = 5;
alert (bufferNumberWithZeros(theNumber, 2));
////// buffer number with zeros //////
function bufferNumberWithZeros (number, places) {
var theNumberString = String(number);
for (var o = 0; o < (places - String(number).length); o++) {
theNumberString = String("0" + theNumberString)
return theNumberString
Thank you!
alert(time());
function time(){
var date = new Date();
var d = date.getDate();
var day = (d < 10) ? '0' + d : d;
var m = date.getMonth() + 1;
var month = (m < 10) ? '0' + m : m;
var yy = date.getYear();
var year = (yy < 1000) ? yy + 1900 : yy;
var hours = date.getHours();
var minutes = date.getMinutes();
var seconds = date.getSeconds();
if (hours <= 9) hours = "0" + hours;
if (minutes <= 9) minutes = "0" + minutes;
if (seconds <= 9) seconds = "0" + seconds;
todaysDate = hours + ":" + minutes + ":" + seconds;
return todaysDate.toString();
Thank you!
While both of the above answers are correct, I prefer the following method as it is slightly more succinct:
function makeTwoCharString(intIn){
return ("0" + intIn.toString()).slice(-2);
As long as the input is between 0 and 99 (inclusive) it will return the desired two digit string.
Combining with your code gives:
alert(runTime());
try{
var hours = makeTwoCharString(digital.getHours());
var minutes = makeTwoCharString(digital.getMinutes());
var seconds = makeTwoCharString(digital.getSeconds());
