I'm trying to copy blocks of text from one file to a series of new files - each block in it's own file,
The following code works -- USUALLY. occasionally the text in the new file is truncated in the middle (with no pattern as to when it is truncated.
the alert shows the complete text block so I know the sel is correct
any ideas as to what could be causing the problem?
thanks
app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
app.findGrepPreferences.findWhat=" newblock";
found=app.activeDocument.findGrep();
for(i=0;i<found.length-1;i++){
ipStart=found.index;
ipEnd=found[i+1].index-1;
sel = found[0].parentStory.characters.itemByRange(ipStart,ipEnd);
//alert(i+"\r"+sel.contents);
nd=makeNewDoc();// creates new doc - sets margins
ntf=nd.pages[0].textFrames.add();
gb=ntf.geometricBounds;
gb[2]=gb[3]=200;
gb[0]=gb[1]=0;
ntf.geometricBounds=gb;
sel.duplicate(LocationOptions.AT_BEGINNING,ntf);
As per your need I can understand, I think you should try this
...app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
app.findGrepPreferences.findWhat="newblock";
var ipStart = null;
var ipEnd = null;
for(i=0; i < found.length; i++){
if(i==0){
ipStart = found.characters[0].index;
else{
if(i < found.length-1){
ipEnd=found.characters[0].index-1;
else if(i < found.length){
Hi there,
If you are more concerned about text only, then instead of grep you should try text search, so your code should be like this,
app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
app.findTextPreferences.findWhat=" newblock";
found=app.activeDocument.findText();
nd=makeNewDoc();
gb[2]=gb[3]=200;
gb[0]=gb[1]=0;
Hi
I need to use grep -- "new block" is preceded by numbers that have to be included. I left that out because it doesn't affect the script example
Follow up experimenting: if I make the textFrame huge (so the entire text block fits into the frame) then it seems to work properly...
Which doesn't make any sense (as far as I can see)
Any ideas why?
thanks
var ipStart = null;
var ipEnd = null;
if(i==0){
else{
//******you can choose here if you want to add character after last newblock to the end of your story or not******//
ipEnd=found.parent.characters[found.parent.characters.length-1];
var nd = app.documents.add();
gb[2]=gb[3]=200;
gb[0]=gb[1]=0;
What if you duplicate the text into ntf.parentStory (instead of ntf)?
Marc
