Got a video file recorded using OBS and Blackmagic Decklink 4K card. It was encoded using GPU and ended up in format like this:
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.2
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 46 min 50 s
Bit rate mode : Constant
Bit rate : 35.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.281
Stream size : 11.2 GiB (100%)
Color range : Limited
Matrix coefficients : BT.470 System B/G
I have an 8 core xeon and 1080ti gpu, but program lagged hardly when I tried to edit something. Playback lagged too, cpu load was near 80%. What's wrong? Should I update some codecs or settings? CUDA rendering works fine, I checked.
It transcodes everyting ok, but with high cpu usage.
Hi AnnaV,
What happens if you transcode or create proxies for the footage?
Kevin
It may be more convenient, but...if it's not working...
Higher CPU usage for higher bandwidth clips is normal. Continue to transcode then.
Kevin
If you have a DeckLink, why would you choose OBS instead?
I stream, it's more convenient for me to record video in OBS.
