Scripts break in InDesign 2018 CC.
Jun 04, 2018 Jun 04, 2018
I have a small automation project I want to do—note that I haven't done any scripting in InDesign since CS6—and opened up Script Editor.
First problem: File ► Open Dictionary... and using that to open InDesign spit back a blank window with the message "Nothing to see here, move along."
Oooookay. So I posted the following script:
tell application "Adobe InDesign CC 2018"
    tell document 1
        set aNewPage to make page at end
    end tell
end tell
and I got the following error:
error "The variable page is not defined." number -2753 from "page"
More concerning was that in opening up the Scripts window in InDesign, I discovered that the AddGuides script doesn't work, either; the JavaScript version does, but the AppleScript one throws an error.
So, how do I get the current scripting dictionary for InDesign CC 2018? Did something change with the scripting lately?
Scripting
982
Engaged ,
HI
yeah, things have changed a ee nit since CS6
try this
    set myDoc to make new document with properties {document preferences:{page width:100, page height:100, facing pages:false}}
    tell myDoc
        set aNewPage to make page at after page 1
    end tell
end tell
As far as the script goes, it doesn't matter if I make a new document or use document 1; the problem is that when I type "make page", it assumes "page" is a variable rather than an object. "at end" or "at after page 1" or whatnot doesn't really matter, either.
Engaged ,
Jun 05, 2018 Jun 05, 2018
just in case, is your document active?, as it will not work unless it is so
your code works fine if I have an active document
Engaged ,
forgot to mention, to get the dictionary from Script Editor, open it, in the file menu select open dictionary, then scroll to your desired app
Er, yes, that's exactly what I did. And that's the result I got.
("First problem: File ► Open Dictionary... and using that to open InDesign spit back a blank window with the message 'Nothing to see here, move along.'")
